240v Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 02:24 AM   #1
Question
240v motor
i have a crompton betts 2hp class E 5 PIN ELECTRIC motor i need to
reconect the wires i have a black+red+white+white/blue stripe coming out
of the coil then there is 2 compasitors + 1 over load switch pins readout
Z1
A1
5 (this is the pin layout )
A2
4
pins A1 AND A2 are to the left of z1-5-4
this is for an australia 240v motor.
so lets hope some one out there can help.
thanks guys or girls
outback4u is offline   Reply With Quote
Old 01-24-2010, 11:21 AM   #2
Rewards Points: 126
Got a picture? Because I have no idea of what you are asking about. What coil? What do you mean? Take a few pictures or write down all the specs from the nameplate. All the specs and information regarding model, serial number? Write down everything.
Old 01-24-2010, 05:01 PM   #3
reply
thanks jv for your reply i will do as you asked and get back to you
Old 01-24-2010, 05:03 PM   #4
reply to photos
thanks j v i will do as you asked and get back to you
thanks heeps
Old 01-24-2010, 06:50 PM   #5
" Euro " electrician
frenchelectrican's Avatar
You may get the answer pretty soon due I will get ahold of my freind from Aussie area so he should be famuir with that motor hook up. Merci,Marc
Old 01-24-2010, 08:21 PM   #6
i thank you and await your reply
Old 01-25-2010, 09:29 PM   #7
hi j v i tryed to send pic but to big for limit. so here is the specs of the name plate.plus a diagram is in the attachments here gose.
BETTS ELECTRIC MOTORS
a division of james n kirby p/l australia
MOD NO. 15HO13-21
240 VAC. 50HZ 1PH 8.4A 2HP CS90
WATTS OUT 1300. DUTY M.C.R C.S.C.R
CLASS E. INSUL 2835 R.P.M
sure hope this helps for my sake. and many thanks for your time
regards. outback4u
i belive crompton may own betts i tryed here in oz but no go
thanks again anyhow
Old 01-26-2010, 09:09 PM   #8
J v reply please
diagram2.jpg J V DID YOU GET THIS DIAGRAM ATT:
Old 01-26-2010, 09:49 PM   #9
Info on 240v motor
j.v i don`t now if iam sending this reply right just incase iam not. here it is
BETTS ELECTRIC. a division of james n kirby p/l australia
MOD NO:15HO13-21
240 VAC. 50HZ. IPH. 8.4A CS90
watts out 1300. duty m.c.r c.s.c.R
CLASS-E. INSUL 2835 R.P.M
can you let me know if you get this reply.
diagram is in your attachment
Old 01-26-2010, 10:33 PM   #10
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
MOD NO. 15HO13-21
regards. outback4u
thanks again anyhow
Not familiar with that motor but blue is neutral not live .. brown is live.
Can you by chance look at the nameplate there should be a wiring diagram on it. If not can you tell or show us how the wires coming from the capacitors and overload connect to the 5 pins ?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-26-2010, 10:56 PM   #11
your right about the blue and brown my mistake there is no other info on the motor
like all other wires the capacitors + the overload button wires are just hanging loose
not connected this is what i would like to know where they go
this was made in australia by betts
thanks
Old 01-29-2010, 01:02 AM   #12
iam still waiting i hope you haveing forgot about my motor prblem
regards
outback4u
Old 01-29-2010, 02:21 AM   #13
UAW SKILLED TRADES
Stubbie's Avatar
Sorry but I am not familiar with those terminal markings. I would be guessing. I could tell you how I think it is wired based on the fact it is capacitor run and capacitor start. Not a good idea unless your positive or you may burn the motor up.
Stubbie
Old 01-29-2010, 06:38 PM   #14
I allready got ahold of my freind from that area and he should be in touch shortly..
Merci,Marc
Old 01-29-2010, 08:41 PM   #15
Merci,Marc
thanks bud sorry for being a pain manny thanks
Do you think a tool running at 240v works better than at 120v? Piedmont Electrical 39 07-03-2009 09:50 PM
Oiling Trane XB1000 AC Fan Motor Build HVAC 5 06-19-2009 04:05 PM
Motor control wiring problem dgr68 Electrical 8 01-04-2009 05:13 PM
Air Compressor Motor Hums, Trips Breaker pointertopica HVAC 10 12-02-2008 10:20 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 06:30 PM
