240V Kiln Outlet To Air Conditioner Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2008, 06:27 PM   #1
240V Kiln Outlet to Air Conditioner Outlet
I'm replacing a 240V 50A kiln outlet with a 240V 15A breaker, which will have 1 outlet only for a air conditioner 15A. I want to be sure I've done the wiring correctly.
Here is a diagram-
Ken
artman is offline   Reply With Quote
Old 06-28-2008, 08:47 PM   #2
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
That is correct assuming the green does not connect to the circuit breaker.
John
jrclen is offline   Reply With Quote
Old 06-28-2008, 10:58 PM   #3
Thanks, John! The green comes into the box, attaches to a 1 location of 4 screw bar, which the outlet green also connects to. There is no polarity issues with the two blacks, correct?
Ken
Old 06-29-2008, 01:48 AM   #4
Idiot Emeritus
Rewards Points: 1,492
On a 240 volt circuit, polarity doesn't make any difference at all. Polarity only matters where the neutral is involved. There's no neutral in your circuit. Your drawing will work just fine.
Rob
micromind is offline   Reply With Quote
Old 06-29-2008, 02:21 AM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Rob
He may encounter a problem getting 50 amp wire to connect to a 20 amp breaker. I believe most 20 amps will accept 8 awg but not 6 awg. This is of course assuming he used a 60 C column cable for the supply to the kiln.
Old 06-29-2008, 02:29 AM   #6
Idiot Emeritus
Good point, I guess you could pigtail it. There's no way you'd get even an 8 into a 20 amp receptacle.
Rob
Old 06-29-2008, 03:14 PM   #7
awg to breaker
Thank You, for your help!
I was able to attach the heavy kiln wire into the breaker box connectors at the top. I'm not versed in wire sizes- they were about 1/4 dia. multi-strand copper.
From the breaker, I ran 12/3 out to the outlet, this I did not mention. Looks good?
Ken
Old 06-29-2008, 03:29 PM   #8
Idiot Emeritus
Perfect. It'll work just fine, and I don't see any code issues.
Rob
Old 06-29-2008, 07:21 PM   #9
Rob- I sure appreciate your help. Next time I'll hire it out! A bit too much anxiety and a few too many trips for conduit hardware.
John, Stubbie, Thank You, all!
Ken
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Adding an outlet on a 240V circuit? Kjunk Electrical 6 05-31-2008 10:27 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
