240v Hot Tub Bonding - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2010, 10:03 AM   #1
240v hot tub bonding
I am putting a 240v hot tub on an existing concrete patio that does not have an equipontential grid in it. It does have wire mesh as a typical patio does. The hot tub will hard-wired (not plugged). How do I install an effective bonding grid? What can be done besides a metal grid (wood walkways around?)
Scott_farkas is offline   Reply With Quote
Old 08-30-2010, 10:32 AM   #2
Rewards Points: 160
You need to contact the inspector and go over the project/plans. Find out now what he wants. The equipotential bonding grid is a requirement and important for safety. This is serious business and you better find out now what is required before you do anything else. [STOP] [CALL]
Old 08-30-2010, 10:54 AM   #3
I understand the requirement and have already contacted the inspector. My question was "How do I install the grid" and who understands the Article 680.26
I understand the requirement is needed for safety, and I have the elctricle inspector requrement, which is why I asked if anyone understands code 620.26 "Equipotential Bonding" and how to satisfy the electrical code.
Old 08-30-2010, 11:06 AM   #4
Licensed electrician
Rewards Points: 1,610
Your inspector may make you chip out to access the wire mesh that is already in the slab. They may also have an alternative idea to satisfy the grid requirement.
Wiring two 240v appliances to one circuit brandykn Electrical 2 02-02-2010 09:44 PM
New 240V receptacle reads zero volts Madroaster Electrical 32 09-19-2009 12:35 PM
Do you think a tool running at 240v works better than at 120v? Piedmont Electrical 39 07-03-2009 09:50 PM
wiring a 240V baseboard heater 777 Electrical 10 05-17-2009 10:47 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
