Old 10-16-2012, 12:09 PM   #1
240v electric baseboard heat wiring diagram
I am installing two baseboard electric heaters on a wall thermostat. They are 4' each for a total of 2000w. I would like to see a diagram of the wiring. The installation instructions from Honeywell and Fahrenheat are inadequate. I want both controlled by one thermostat.
I am more concerned with how to connect the red/black in the heater and also exactly what is meant by "multiple must be wired in parallel".
santro is offline   Reply With Quote
Old 10-16-2012, 12:40 PM   #2
Are they designed to operate on 120V, 240V, or is the voltage user selectable?
What are the mfr's and model numbers of both the heaters and the T-stat?
Dave632 is offline   Reply With Quote
Old 10-16-2012, 01:24 PM   #3
240v F2544NWC Fahrenheat heater and Honeywell CT410A,B thermostat.
Old 10-16-2012, 01:47 PM   #4
Do you have the A or the B version? A version is single pole (2 wires) and B version is double pole (4 wires). Are there colored leads connected to the T-stat (black and red, probably) or are there labeled connection terminals (such as L1, T2, etc.)?
Old 10-16-2012, 02:08 PM   #5
You have more than one heating unit, so it's called "multiple". In parallel means that both heating units are connected to 240+ and 240-, as opposed to a series connection, where the "output" wire of one unit feeds into the "hot" lead of the other. If you did a series connection, each heater would only see 120V, and you'd get much less heat than you want.
The diagram below shows a parallel connection. Ground omitted for clarity.
Old 10-16-2012, 02:58 PM   #6
I have the B ver. 4 wire The heater has a safety limit wired in it, one wire red goes to the element, the other, black has a wire nut and comes from the safety limit then to the other end of the element. Do I simply break the wire nut connection and connect red/black from the thermostat to these two ends?
Old 10-16-2012, 03:29 PM   #7
In case you don't have them, you can see the installation notes here.
Bring the cable (black, white, ground) coming from the T-stat into the junction box that's a part of one end of the heating unit. Wire-nut the two grounds together.
The wire from the safety cutoff should also be black. So you have two blacks wire-nutted together. Remove the wire nut.
Use a wire nut to connect the white from the T-stat cable to either one of the blacks that you just separated.
Use a wire nut to connect the black from the T-stat cable to the other black that you just separated.
Check:
  • Grounds together.
  • White from cable to one of the blacks from heater
  • Black from cable to the other black from heater.
Run another cable from the junction box to the second heater, and repeat the above steps.
Old 10-16-2012, 04:01 PM   #8
Thank you!! Sometimes we complicate things. You made it seem so simple. I appreciate your help very much. Now I can go finish this job.
ceramic vs electric baseboard heat ut7000 HVAC 2 01-23-2012 06:49 PM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 11:53 AM
wiring diagram for three zone in floor radiant heat including pumps. szarapka Plumbing 1 11-05-2011 08:16 PM
Electric Wiring for Pool Heater (heat pump) tazmajazz Electrical 7 10-21-2009 09:49 PM
Electric Ceiling heat wiring jenoble99 Electrical 6 12-16-2008 08:36 AM
