Old 03-30-2011, 02:43 PM   #1
240v Dryer outlet reads zero
My dryer runs but wont heat. after checking everything 3 or 4 times by the book I tried testing the outlet. Each "hot" leg reads 120 volts but when I test both hots I get zero volts. Please, please can someone help. I am going out of my mind.
Frank23 is offline   Reply With Quote
Old 03-30-2011, 02:53 PM   #2
Each hot lead reads 120 to ground but no reading between the hots?
Have you moved any wires in your service panel lately? It sounds as if you have both leads on the same buss.
AandPDan is online now   Reply With Quote
Old 03-30-2011, 03:12 PM   #3
I=E/R
a7ecorsair's Avatar
Has this ever worked or is this a new connection? If it is new wiring it sounds like both sides are being fed from the same bus bar in the panel.
a7ecorsair is offline   Reply With Quote
Old 03-30-2011, 07:59 PM   #4
Sounds like both hot lines are coming from the same phase,
For 240v you need two hot lines from different phases.
Check the input side to each breaker,
Do they come from the same hot line ?
If so this is wrong.
They must come from different phases or hot lines.
dmxtothemax is offline   Reply With Quote
Old 03-30-2011, 08:03 PM   #5
Journeyman Wireman
Have you taken a voltage reading at the panel? Sounds like one leg of the 2 pole breaker has died and you are reading 120v to ground via the heating element.
Go to the panel, turn off breaker, remove both wires from the two pole breaker, turn on breaker and take a voltage reading from each pole to the neutral bar.
Jupe Blue is offline   Reply With Quote
Old 03-30-2011, 08:04 PM   #6
joed's Avatar
Is this a new install?
Did you use a full size double pole breaker or a mini tandem breaker?
Is the breaker installed properly? Some panels can have the double pole breaker installed so that both tabs are on the same leg.
Do not PM with questions that can be asked in a forum. I will not respond.
Electric range in dryer outlet Greenlevel Electrical 5 02-03-2011 06:20 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Strange 240v outlet BearcatBengal Electrical 30 03-03-2010 12:10 AM
Use Dryer Outlet for Woodworking Tools mikewrobel Electrical 7 08-02-2009 12:01 PM
Dryer outlet vs. Range outlet cindakay Electrical 24 04-13-2009 07:01 PM
