240v Dryer Outlet Issues - Electrical - DIY Chatroom Home Improvement Forum
Old 03-11-2013, 10:38 AM   #1
I've been trying to troubleshoot my dryer for the past couple months to no avail. So far I've replaced the heating element, and then the electronics control board per what the technician's guide said to do.
I've been inspecting the outlet (which I should have done initially) and I'm getting around 120v from each hot wire to the neutral and to the ground. I'm not getting around 240v from one hot to the other however. I am only getting 104v and I was wondering if this is actually normal, and if not what could be the problem?
I am testing voltages from the end of the cord btw, since my multimeter isn't able to get a reading in the deep 240v outlet.
benskinner is offline   Reply With Quote
Old 03-11-2013, 10:40 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,380
Ayuh,.... You should be gettin' 2 legs of 120v each, for a combined 240v...
Which it sounds as though ya are....
Bondo is online now   Reply With Quote
Old 03-11-2013, 10:45 AM   #3
My only question is when you go from the two hot sources it won't read around the full 240v?
Old 03-11-2013, 10:46 AM   #4
eastcoastsparky's Avatar
Rewards Points: 150
What are you using to test the voltage
eastcoastsparky is offline   Reply With Quote
Old 03-11-2013, 10:47 AM   #5
Innova 3320 Multimeter
Old 03-11-2013, 10:49 AM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
Any electrical work lately?
Do you have fuses or breakers?
Have you reset the breaker?
Old 03-11-2013, 10:50 AM   #7
Moved into a new apartment and the dryer worked for about a week before it stopped working. Haven't been able to solve the problem in the few months since then. It has a set of two breakers to the outlet that I've reset a few times.
Old 03-11-2013, 10:55 AM   #8
Are you testing the outlet voltage with the dryer plug totally removed?
Did this dryer previously work plugged into that outlet?
Billy_Bob is offline   Reply With Quote
Old 03-11-2013, 10:57 AM   #9
It worked for around a week in the same outlet and then stopped working. No the plug is still attached to the back of the dryer, do you think it would read differently if unhooked from the back?
Old 03-11-2013, 10:57 AM   #10
jbfan's Avatar
Rewards Points: 488
Call the landlord.
Old 03-11-2013, 11:01 AM   #11
MarginallyQualified
Rewards Points: 2,464
There should be a double pole breaker.
Start with that issue when you call your landlord.
Old 03-11-2013, 11:05 AM   #12
It is a double pole, my mistake for making it sound like two separate breakers. That's just the way I think of it since it spreads over two breaker spots.
Old 03-11-2013, 11:37 AM   #13
Turn the breaker fully off, then back on.
And if measuring the voltage with the dryer still plugged in, one "hot" might be working and the other "hot" not working. But the hot voltage travels through the dryer to the other hot. Thus you get a reading.
With the dryer unplugged, that non-working hot would (should) not have any reading.
Possible just half the double breaker tripped or there is a wiring problem like a loose connection (landlord problem if a rental).
P.S. Turn OFF the breaker before unplugging it from the outlet (if you are going to do that). Do not disconnect the wire from the back of the dryer for testing the voltage!!!!
Old 03-11-2013, 11:59 AM   #14
what sort of tool would I need to test the actual plugs of the 240v outlet. The contacts on my multimeter aren't long enough to get a reading from any of the outlet plugs so I don't have a way to test it without the dryer being plugged in.
Old 03-11-2013, 12:05 PM   #15
Rewards Points: 446
You're dealing with 240v at high amperage... ever heard of Arc Flash?
old_squid is offline   Reply With Quote
250v 50A Stove plug convert to 240v 30A for dryer wololo696 Electrical 5 01-01-2013 12:30 PM
Looking tp put a 240v outlet in garage. drewzilla Electrical 31 10-09-2012 03:54 PM
soggy outlet pipe for dryer? darsunt Appliances 5 08-04-2010 12:28 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Clothes Dryer / Outlet homercavazos Electrical 8 10-30-2007 04:14 PM
