240V Breaker In Single Panel Space? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-23-2011, 07:05 PM   #1
Rewards Points: 27
240V breaker in single panel space?
This is probably a dumb question, but here goes...
I have a Q06-12L-100S subpanel, which has six spaces for breakers. So, I could put in 12 half-size breakers. But, I'm short on space and I need to add a 240V circuit.
Do I have to use two of my six spaces for a 240V breaker? Or, is there a breaker that fits into a single space?
Eric
mn1247 is offline   Reply With Quote
Old 07-23-2011, 07:10 PM   #2
Electrical Contractor
kbsparky's Avatar
You will have to use two spaces for that 240 Volt circuit. That will leave 4 spaces, or up to 8 single pole circuits, if you use tandem type breakers.
Square D does not make tandem type QO 2-pole breakers these days.
-KB
Old 07-24-2011, 08:56 AM   #3
Rewards Points: 27
Thanks for the explanations. So, what would you suggest I do if I need more space? Would I need to change out the whole panel? Or, would a "quad breaker" be the way to go?
I only need one 240V circuit. And, all the existing spaces already have tandems, except one.
Eric
Old 07-24-2011, 10:15 AM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,904
A quad is definitely the best solution to that problem, if they make a suitable quad for that panel. You can use the two other poles that you're not using for the 240V circuit for something else.
mpoulton is offline   Reply With Quote
Old 07-24-2011, 11:09 AM   #5
Licensed electrician
Rewards Points: 1,296
I have never seen a QO quad. I think the solution would be to install a larger panel. I they use the same brand all the parts can transfer over.
mpoulton (07-24-2011)
new sub panel BlueBSH Electrical 11 01-22-2012 09:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Hot water flate rate conversion to breaker panel curlycord Electrical 1 05-06-2009 08:24 PM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 12:18 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 11:37 AM
