240v Baseboard Heaters - Electrical - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 08:48 PM   #1
240v baseboard heaters
I want to wire 3 1000w heaters on the same circuit in three different rooms. I have existing 2 wire run to 2 existing heaters and am adding one more. I'm looking for a wiring diagram to figure this out.
Certcarp is offline   Reply With Quote
Old 02-21-2012, 09:12 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
What size wire is there?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-21-2012, 10:33 PM   #3
Licensed electrician
Rewards Points: 1,024
Where is the thermostat? Will the new unit be controlled with the others or a new T-stat?
Different Load Baseboard Heaters in Parallel pankaek Electrical 4 03-25-2011 03:52 PM
Newbie question - thermostat functioning and baseboard heaters keith-k HVAC 2 10-26-2010 10:20 AM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 10:30 AM
Relay controlled baseboard heaters a7ecorsair Electrical 6 06-20-2010 02:31 AM
wiring a 240V baseboard heater 777 Electrical 10 05-17-2009 11:47 AM
