Old 12-09-2008, 12:23 AM   #16
240V baseboard heater - 12/2 or 10/2 ?
Meanwhile, fixture is my foyer is now hung up without a box.
pmoe is offline   Reply With Quote
Old 12-09-2008, 12:30 AM   #17
DIYer
You should make sure this guy is really an electrician and not some kind of con artist. I agree with the others that you need to talk to the inspector and stop letting this guy into your house.
Gigs is offline   Reply With Quote
Old 12-09-2008, 01:02 AM   #18
He works for a local electrical contracting company here who does work on some high brow properties that Duke owns.
Old 12-09-2008, 01:51 AM   #19
DIYer
People have gotten jobs with forged credentials before. I'm not saying that's what happened here... but something is up.
Old 12-09-2008, 06:48 AM   #20
An old Tradesmen
Also told me a 240V heater would use a lot more energy than a 120.
If he told you that.
Time to look for another electrician.
Old 12-09-2008, 06:49 AM   #21
An old Tradesmen
He may work for an electrical contractor.
But that doesn't make him an electrician, let alone a qualified electrician.
Old 12-20-2008, 12:57 AM   #22
I'm finally getting around to completing the jobs that the contractor never did. (Funny, he did take the money.)
Here's what the foyer light wiring looks like:
Old 12-20-2008, 01:17 AM   #23
...Oh my god
rgsgww is offline   Reply With Quote
Old 12-20-2008, 10:46 AM   #24
UAW SKILLED TRADES
Stubbie's Avatar
The best way to bring these phoney electricians out in the open is to tell them you want permits as micromind eluded to. They can't get the permit because they are not licensed electricians but pass themselves off as such.
Old 12-20-2008, 11:40 AM   #25
>>> a 240 volt heater uses more energy than a 120 volt heater
Using 240 instead of 120 volts allows the same set of wires to carry more energy.
The 12 gauge wires allow 16 amps for heating or other continuous loads. 16 amps at 240 volts is equal to 32 amps at 120 volts. For the latter you need two circuits wired 12 gauge or one circuit wired 8 gauge.
I would expect a 240 volt baseboard heater rated for X watts to give the same amount of heat as a 120 volt baseboard heater rated for X watts, assuming no significant voltage drop in the wiring.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
baseboard heater not working bobcatnj Plumbing 6 10-30-2008 10:21 PM
forgot a line to the baseboard heater! fauer Electrical 1 10-19-2008 10:17 PM
Baseboard Heater: Can I wire it to plug into an AC recepticle? JBiz Electrical 3 12-01-2007 09:42 AM
240v / 20.9A Heater jbclbc Electrical 15 01-19-2007 09:53 AM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
