240v Appliances With 120V Outlets - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-01-2009, 07:02 PM   #16
Journeyman Wireman
Why don't you just get some quotes for adding the electric. It doesn't sound like you are going to do it yourself, anyway
jbberns is offline   Reply With Quote
Old 07-01-2009, 09:03 PM   #17
Electrical Contractor
kbsparky's Avatar
Originally Posted by kbsparky View Post
...Best to stick with gas appliances in your situation for the time being.
Originally Posted by jbberns View Post
Don't go with this idea!
And you have a problem with sticking with gas appliances ... why?
-KB
Old 07-01-2009, 09:31 PM   #18
Journeyman Wireman
He said he has pretty new electric appliances. Only reason
Old 07-01-2009, 09:33 PM   #19
Journeyman Wireman
You can configure an electric dryer to operate on a 120 Volt source.
Be advised that it will take 3-4 times longer to dry a wet load of clothes, when so connected.
If you connected an electric range in a similar manner, it might also work, albeit quite marginally.
The heating elements would only produce their rated wattage, and cooking would be quite a task with limited heat output.
This idea.
Old 07-02-2009, 08:38 AM   #20
Rewards Points: 1,500
Reconfiguring a 240 volt electric dryer to run on 120 volts also requires center tapping the heating element. (If you don't know what that means then this is not a DIY project for you.) Neutral goes to the middle and the two ends are tied together and connected to the hot line. The heat will then be the same as the original 240 volt power supply would yield.
Estimate the total amperes drawn at 120 volts to be twice that at 240 volts. (The heating element uses the majority of the energy.) Should this be more than 20 amps (20 amp circuit) then the project is not practical. You would need to string a new circuit for a 120 volt load greater than 20 amps (80% or 16 amps for something continuous or long running like an air conditioner) and if you need to do this you might as well string a 240 volt circuit.
AllanJ is online now   Reply With Quote
Old 07-02-2009, 09:09 AM   #21
DIYer
Wouldn't you need to be able to weld nichrome to center tap the heating element? Or do they already have a tap there?
Gigs is offline   Reply With Quote
Old 07-02-2009, 11:05 AM   #22
Rewards Points: 128
I would fish the cables, install the recepts and connect to the panel and be done with it. Gas appliances cost more to buy new. But IMO are the better option. I like gas, but if my appliances are electric and in almost new condition I would pull the trigger. Watch that meter spin.
240v Air Compressor to 120v help ruacoltsnut General DIY Discussions 10 11-11-2010 04:05 PM
Do you think a tool running at 240v works better than at 120v? Piedmont Electrical 39 07-03-2009 09:50 PM
2008 NEC - 120V and 240V receptacles on the same MWBC? ScottR Electrical 10 06-05-2009 10:39 PM
Multiple 240V appliances wirefixer Electrical 2 03-29-2009 02:00 PM
Understanding 120V branch loads in 100A 240V system WaldenL Electrical 17 02-17-2009 09:15 AM
