240V/30A Outlet Install With 1/2" 2 Pole Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 09:59 PM   #1
240V/30A outlet install with 1/2" 2 pole breaker
Hey Guys & Gals, Spent a few hours reading up on the forums and I still can't decide if I can run a new 240V dryer outlet from the 1st floor breaker or the main breaker in the basement. I have one unused slot in my 1st floor breaker The load center is a Murry LC1224L1125. The sticker on the panel states that its a 125A load center. The dryer is rated at 30A. What I wanted to know is if I can run a new 240V 2 pole breaker from this unused slot. I attached a few pics. I know that there are 2 pole breakers that can fit here, but will it work? Thanks for the help.
240V/30A outlet install with 1/2" 2 pole breaker-img00007-20110202-2224.jpg   240V/30A outlet install with 1/2" 2 pole breaker-img00008-20110202-2224.jpg
neal0713 is offline   Reply With Quote
Old 02-02-2011, 10:14 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 420
No.
Those are not 2 pole breakers.
Those are tandom breakers, or 2 breakers in the same frame.
Since tandom breakers fit, you would have to remove the 3 breakers( above the gfci breakers) replace one with a tandom, and put a 2 pole into the other slots.
Old 02-03-2011, 04:34 AM   #3
dSilanskas's Avatar
You really should check to see if that panel can have that many split mini breakers before you add two more....
dSilanskas is offline   Reply With Quote
Old 02-03-2011, 05:34 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
You say the first floor panel (which is a sub-panel) is 125 amps, that is the rating of the panel, not necessarily the way it is cabled/breakered. Check the breaker that feeds this sub in the main panel to determine the capacity of the sub.
Coastal South Carolina
Old 02-03-2011, 08:18 AM   #5
Awesome, thanks for the help!
Old 02-03-2011, 10:35 AM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
The OP gave the panel model # as a LC1224L1125
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Replaced Outlet, but now tripping the circuit breaker bman598 Electrical 9 05-21-2009 07:35 PM
HOW MUCH?? To have utility company install new pole? ehoez Electrical 3 06-26-2008 10:18 AM
Three way light switches and double pole breaker ShawnColes Electrical 6 04-15-2008 08:25 PM
Breaker for Spot light and outlet receptical hgiljr Electrical 4 08-16-2007 01:10 PM
