-   -   240V/30A outlet install with 1/2" 2 pole breaker (http://www.diychatroom.com/f18/240v-30a-outlet-install-1-2-2-pole-breaker-94382/)
neal0713 02-02-2011 09:59 PM
2 Attachment(s)
Hey Guys & Gals, Spent a few hours reading up on the forums and I still can't decide if I can run a new 240V dryer outlet from the 1st floor breaker or the main breaker in the basement. I have one unused slot in my 1st floor breaker The load center is a Murry LC1224L1125. The sticker on the panel states that its a 125A load center. The dryer is rated at 30A. What I wanted to know is if I can run a new 240V 2 pole breaker from this unused slot. I attached a few pics. I know that there are 2 pole breakers that can fit here, but will it work? Thanks for the help.
http://www2.snapfish.com/snapfish/sl...NAME=snapfish/
jbfan 02-02-2011 10:14 PM
No.
Those are not 2 pole breakers.
Those are tandom breakers, or 2 breakers in the same frame.
Since tandom breakers fit, you would have to remove the 3 breakers( above the gfci breakers) replace one with a tandom, and put a 2 pole into the other slots.
dSilanskas 02-03-2011 04:34 AM
You really should check to see if that panel can have that many split mini breakers before you add two more....
rjniles 02-03-2011 05:34 AM
You say the first floor panel (which is a sub-panel) is 125 amps, that is the rating of the panel, not necessarily the way it is cabled/breakered. Check the breaker that feeds this sub in the main panel to determine the capacity of the sub.
neal0713 02-03-2011 08:18 AM
Awesome, thanks for the help!:thumbup:
Stubbie 02-03-2011 10:35 AM
The OP gave the panel model # as a LC1224L1125
