240V 30 Amp Room A/C: 10-2 Or 10-3? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2008, 05:30 PM   #1
240V 30 amp Room A/C: 10-2 or 10-3?
Hi,
I'm putting a thru the wall air conditioner in my garage\shop, probably an 18,00 btu unit which usually req 240V and 30 amps. The plug types I have seen on these are all 3 prong. I read somewhere that most modern 240V circuits are 4-wire, ie. 10-3. Since the plugs are only 3 prong, will the 10-2 suffice?
Thanks,
Grommet
Grommet is offline   Reply With Quote
Old 03-22-2008, 06:00 PM   #2
When is fishing season?
CowboyAndy's Avatar
A/C units generally are straght 240 volt, which would only require 10/2.
The best thing to do would be to pick out a unit first, then you would know the wiring requirments for that model.
You can still run 10/3 if you like, and if you get a model that is 120/240v (not very common) you will be set... if not then you would not use the white (neutral) wire, but it would be there for future expansion.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-22-2008, 06:04 PM   #3
YID
Originally Posted by Grommet View Post
Hi,
Thanks,
Grommet
Yes 10/2 will suffice. Two Hot wires and a Ground wire.
YID is offline   Reply With Quote
Old 03-22-2008, 07:11 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
NO, NOT 240v applainces.
This applies to 120/240v electric cooking appliances and dryers ONLY, and not all of them. Some are straight 240v.
Old 03-25-2008, 03:07 PM   #5
Thanks Guys!
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 02:51 PM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 05:34 PM
Room to Room Vent cjpilot HVAC 5 12-02-2007 08:53 PM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 03:08 PM
