Old 12-04-2009, 10:14 PM   #1
240v 3 prong outlet ISSUES!!
So to this point I've read just about everything on 240v, 3 prong wiring and I'm still stuck.
I bought a 240v, 4800w 20amp garage heater. I added the 30amp circuit (noted on the box as the required circuit), ran the 10/2 wire (it happens to be 10 CU 2, if that makes a difference, I was told it didn't), connected the 6-30p outlet, tested L1-ground, and L2-ground, each at 120v and...... the heater doesn't work.
I'm sure I'm missing something tremendously simple, but it's completely evading me.
JanosX is offline   Reply With Quote
Old 12-04-2009, 10:26 PM   #2
Wire Chewer
Red Squirrel's Avatar
Remove the breaker and make sure that it's a on using both busses. I had to shift a few breakers around in my panel to get a DP breaker to use both busses. Your panel might be arranged the same way.
To rule out a connection issue down the line test the two hots right at the breaker (be cautious while you have the cover removed while it's live).
edit: and also test at the plug, never even took into consideration it might be the heater itself.
Old 12-04-2009, 10:28 PM   #3
Xtreme DIY'r
New heater or used ?
Old 12-04-2009, 10:39 PM   #4
You nailed it Red squirrel. I had the double breaker on the same bus.
I knew it was simple, just couldn't wrap my head around it.
Thanks.
Old 12-05-2009, 02:00 PM   #5
Wire Chewer
Glad to hear that worked! Always nice when it turns out to be something simple that requires little change.
Tags
240v, 30amp, garage heater
Pulling 120V outlet from a 240V circuit? npage148 Electrical 12 11-08-2009 12:29 PM
3 PRONG vs. 4 PRONG OVEN OUTLET? Casey_Oakland Electrical 17 05-21-2009 09:26 PM
dryer Outlet change 3 prong to 4 prong oldpirate General Discussion 2 08-06-2008 07:18 PM
240V Kiln Outlet to Air Conditioner Outlet artman Electrical 8 06-29-2008 07:21 PM
Adding an outlet on a 240V circuit? Kjunk Electrical 6 05-31-2008 10:27 AM
