240v/250v Simultaneous Off One Line??? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-17-2012, 05:25 PM   #1
Rewards Points: 30
Question
240v/250v Simultaneous off one line???
Hello,
I was wondering if I could add another outlet for my dryer (250v) from the j box that is powering my stove (240v). The breaker is a duel 40amp and the wire is a 6-3g. Can I add another outlet for my dryer and simultaneously run the stove?
thanx for the help!
psychoguy42 is offline   Reply With Quote
Old 11-17-2012, 05:28 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by psychoguy42 View Post
Hello,
thanx for the help!
It would be easier to pull another branch circuit for the dryer.
Old 11-17-2012, 05:42 PM   #3
Rewards Points: 30
The laundry room is on the other side of the wall where the stove is. I would run another line but the breaker box is on the other side of the house and in the basement. Wanted to avoid running another line if I could.
Old 11-17-2012, 05:47 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I know Stick is going to argue, but I am going to say flat out that you cannot do that. The dryer will spec it be on a 30A circuit and you must follow manufacturer specifications.
The Following User Says Thank You to k_buz For This Useful Post:
jbfan (11-18-2012)
Old 11-17-2012, 06:00 PM   #5
Rewards Points: 30
Can I put in a larger amp breaker to compensate?
Old 11-17-2012, 06:01 PM   #6
k_buz's Avatar
No you cannot.
Old 11-17-2012, 06:05 PM   #7
Rewards Points: 30
Alright. Thanx a whole bunch. Really appreciate the advice. Kinda in the dark with anything higher then 110.
Old 11-17-2012, 06:25 PM   #8
E2 Electrician
Not really argue, my point was he could install a subpanel and refeed the range and the dryer off the subpanel. But as i stated, easier to run a new branch circuit.
Old 11-17-2012, 07:53 PM   #9
" Euro " electrician
frenchelectrican's Avatar
Hello,
thanx for the help!
Short et sweet the answer is no you can not do this.
The dryer do required 30 amp circuit while the stove typically use either 40 or 50 amp circuit depending on conductor size.
I rather run this with new circuit for the dryer and leave the stove circuit alone.
Merci,
Marc
Old 11-17-2012, 08:48 PM   #10
Rewards Points: 1,492
If the dryer takes 30 amps and the stove takes 40 amps, you may not run a single 70 amp circuit directly to receptacles for the two of them.
The maximum circuit amperes rating for each piece of equipment, or an appliance, is stated on its nameplate, stated in the instructions, and/or implied by the size and shape of the power plug.
Tags
240v , 250v , dryer , electrical , stove
Complete blockage of main line mnp13 Plumbing 9 05-29-2012 10:51 AM
Adding a second line to existing septic line Eddietan Plumbing 3 05-10-2012 09:27 AM
Old water supply line a_lost_shadow Plumbing 7 04-19-2012 11:12 PM
Condensate Drain Line Mystery (pan full but no primary clog?) CarrieLP HVAC 21 04-04-2012 11:07 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
