240v 1phase Steam Generator - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2009, 11:21 PM   #1
Question
240v 1phase steam generator
I'm planing to use a 240v 1phase 6kw steam generator for stem shower
link to the website
saunacore.com/residential_commercial_steam_spa.asp
or
cgi.ebay.com/6kW-Steam-Bath-Generators-Dare-to-Compare-WOW_W0QQitemZ270325617864QQcmdZViewItemQQptZLH_Def aultDomain_2?hash=item270325617864&_trksid=p3286.c 0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1 30
so there is my question
how to hook it up to the circuit??
it is 240v 1ph.
is there any good read about it???
thx alot
ps.
I'm working on my own bathroom and I don't want to toast my house
golonaus is offline   Reply With Quote
Old 01-08-2009, 12:39 AM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
link to the website
or
it is 240v 1ph.
thx alot
ps.
What does the manufacture require? They need to give you more details. I looked at the web site buy didn't find any useful details.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 01-08-2009, 12:50 AM   #3
Electrical Contractor
kbsparky's Avatar
First off, your links need some work:
Here is the first one, and here is the ebay one.
I get the impression you are in Canada. I'm not sure what the Codes are on these units up there, so you may have to consult with someone familiar with Canadian codes and rules.
That being said, I would think you can supply power to these units with a 30 Amp circuit, fed by a 10-2 cable. 6000 watts @ 240 Volts is a 25 Amp load.
You may need to install a disconnecting means within sight of the equipment and/or protect it with GFCI if required by the manufacturer's instructions.
Old 01-08-2009, 10:49 AM   #4
I'm in the states but canadian generator suits me best(cheap)
thx 4 all replys
next Q
isn't 30 Amp circuit, fed by a 10-2 cable. a 2 phase
would you suggest any diagram I can look @???
I think I don't understand 1-2 phase difference
thx in advance
Old 01-08-2009, 11:10 AM   #5
You should really follow the advice given in the other forums and call an electrician. This really isn't a project you should learn electricity on.
jerryh3 is offline   Reply With Quote
Old 01-08-2009, 12:06 PM   #6
Your house is supplied by "split-phase" So basically we "split" the 240 into 120 for your outlets with the neutral wire. Your going to use two hots for 240 volts, 240 is the full phase, 120 is half.
I would strongly recommend an electrician because of the possible requirements for such installations. Such as gfi, disconnects, etc.
Check with the manufacturer first.
Some people say that an electricians job is easy and any one can do it. That is totally wrong. It takes years of experience.
rgsgww is offline   Reply With Quote
Old 01-08-2009, 11:23 PM   #7
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
You are in over your head call an electrician. You obviously don't even understand the theory of electricity.
There is no such thing as a stupid question, but there is such a thing as an ignorant person, with a question, trying to learn.
Pudge565 is offline   Reply With Quote
240v Welder powered by portable generator? MRJChannahon Electrical 19 03-30-2009 06:19 PM
240v Welder powered by portable generator jackgerd Electrical 10 11-06-2008 02:38 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Steam Generator Pressure Release Valve runlikegump Plumbing 2 02-13-2007 08:44 AM
Wiring 240v pump to generator - URGENT Benchr Electrical 4 12-19-2006 06:50 PM
