240 Volt Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 02-07-2014, 11:41 PM   #1
dasbinder's Avatar
240 volt sub panel
I would like to run 240v to my garage. The plan is to install a sub-panel, inside the house where the A/C #8 wire exits.
Will a sub-panel support the A/C compressor and 240v to the garage?
Note: Currently the detached garage is fed by a 30A fuse (120v), ran through buried conduit.
http://imgur.com/D3HVRFq - Service Panel Make/Type
http://imgur.com/wkNU8hy - Service Panel Wiring
P.S. I did not think that I could justify starting a new thread when, seemingly, such a similar one already existed. I apologize for any inconvenience.
dasbinder is offline   Reply With Quote
Old 02-08-2014, 12:07 AM   #2
Rewards Points: 512
Please do start a new thread for the benefit of the Original poster, and others.
Installation is the Reverse of Removal.
The Following User Says Thank You to sirsparksalot For This Useful Post:
dasbinder (02-08-2014)
Old 02-08-2014, 07:38 AM   #3
An old Tradesmen
Rewards Points: 7,376
Made this its own thread. So no confuses you and the OP if the OP has more questions.
The Following User Says Thank You to beenthere For This Useful Post:
Old 02-08-2014, 07:44 AM   #4
dasbinder's Avatar
Mods, thank you.
I did not pay close enough attention; I created another thread.
Please delete my other thread "Sub-panel to support A/C (HVAC) and 240v"
Old 02-08-2014, 07:46 AM   #5
An old Tradesmen
Already done.
Old 02-08-2014, 10:12 AM   #6
Licensed electrician
Rewards Points: 1,630
Two problems, the A/C needs its own circuit and there is no neutral in the circuit either. You are going to need to run a new circuit.
Old 02-08-2014, 01:04 PM   #7
dasbinder's Avatar
I updated the image from inside the panel ... http://imgur.com/IL4EAqA
My fuse diagram from when the AC was added, shows this 25A circuit for A/C and Furnace. The 'Range' used to be a an electric dryer, before it was used for the A/C ... http://imgur.com/9sZfgci
Tags
240v , detached , fuse box , garage , sub panel
Use panel as a junction box? LynnX Electrical 18 01-05-2014 05:56 PM
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 05:27 PM
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 10:49 AM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 12:43 AM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
