Old 08-09-2012, 04:59 PM   #1
240 volt 'pony box'
Can I somehow wire a spot within a 240 volt 'pony box' to have it used as 120 volt?
Thanks,
Chris
chris54 is offline   Reply With Quote
Old 08-09-2012, 05:10 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
240 volt 'pony box'
Thanks,
Chris
Please try again. This time give us a few more details.
What do you mean by "a spot within"???
Are you in the US/Canada?
Old 08-09-2012, 05:37 PM   #3
Electrical Contractor
240 volt 'pony box'
If you do not have a neutral wire feeding the panel, you have no way to get 120 volts.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 08-09-2012, 05:43 PM   #4
Master Electrician
240 volt 'pony box'
i sense a "but what about using the ground" question coming on
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-09-2012, 06:25 PM   #5
240 volt 'pony box'
Originally Posted by andrew79 View Post
i sense a "but what about using the ground as the neutral" question coming on
And the answer is, "no."
You may be able to install a neutral bus (terminal strip with plastic or fiber mounting brackets) in the box and then you can string a neutral wire through the conduit (a premade cable without a neutral must be replaced in its entirety by one with).
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
Old 08-09-2012, 08:54 PM   #6
Licensed Electrician
k_buz's Avatar
240 volt 'pony box'
What is a "pony box"?
Not a fan of the new layout.
k_buz is online now   Reply With Quote
Old 08-09-2012, 10:52 PM   #7
Master Electrician
240 volt 'pony box'
sub panel, i hear them referred to as pony panels a lot.
Old 08-09-2012, 11:29 PM   #8
240 volt 'pony box'
Thanks,
Chris
Only if the pony box has a neutral connection !
You cannot use the earth for a neutral !
Does it have a neutral ?
dmxtothemax is offline   Reply With Quote
Old 08-09-2012, 11:42 PM   #9
kevinp22's Avatar
240 volt 'pony box'
i think we ran the OP off. he never said there wasnt a neutral but we are all over him about it..
anyway "a spot within" sounds like shakespeare (Macbeth?)
pony box is below. not UL listed
kevinp22 is offline   Reply With Quote
The Following 2 Users Say Thank You to kevinp22 For This Useful Post:
Evstarr (08-10-2012), mpoulton (08-10-2012)
24 volt AC wiring in same conduit as 220 volt single phase and in same outdoor enclosure as 220 v silgle phase and 3 phase arbailey Electrical 5 05-24-2012 09:43 PM
12 Volt lighting AC or DC johnr9q Electrical 20 11-21-2010 02:12 PM
Want to change a single 240 volt circuit with only one outlet, to a 120 volt circuit with a standard 120 volt outlet. covenant Electrical 7 11-09-2010 07:07 PM
240 volt circuit and 120 volt circuit to shed fortop Electrical 27 06-26-2010 12:37 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
