-   -   240 volt 'pony box' (http://www.diychatroom.com/f18/240-volt-pony-box-153175/)
chris54 08-09-2012 03:59 PM
240 volt 'pony box'
Can I somehow wire a spot within a 240 volt 'pony box' to have it used as 120 volt?
Thanks,
Chris
Speedy Petey 08-09-2012 04:10 PM
Thanks,
Chris
Please try again. This time give us a few more details.
What do you mean by "a spot within"???
Are you in the US/Canada?
jbfan 08-09-2012 04:37 PM
If you do not have a neutral wire feeding the panel, you have no way to get 120 volts.
andrew79 08-09-2012 04:43 PM
i sense a "but what about using the ground" question coming on :(
AllanJ 08-09-2012 05:25 PM
Originally Posted by andrew79 (Post 985137)
i sense a "but what about using the ground as the neutral" question coming on :(
And the answer is, "no."
You may be able to install a neutral bus (terminal strip with plastic or fiber mounting brackets) in the box and then you can string a neutral wire through the conduit (a premade cable without a neutral must be replaced in its entirety by one with).
k_buz 08-09-2012 07:54 PM
What is a "pony box"?
andrew79 08-09-2012 09:52 PM
sub panel, i hear them referred to as pony panels a lot.
dmxtothemax 08-09-2012 10:29 PM
Thanks,
Chris
Only if the pony box has a neutral connection !
You cannot use the earth for a neutral !
Does it have a neutral ?
kevinp22 08-09-2012 10:42 PM
i think we ran the OP off. he never said there wasnt a neutral but we are all over him about it..
anyway "a spot within" sounds like shakespeare (Macbeth?)
pony box is below. not UL listed
https://encrypted-tbn1.google.com/im...bar6aCMbjiAGcx
