09-18-2011, 10:48 PM
#1
240 volt outlet outside
I need to install a 240 volt outlet outside next to an outdoor breaker panel. What is the best way to do this? Do they make a 240 volt assembly or do I need to install a weather proof box?
09-18-2011, 10:53 PM
#2
Electrical Contractor
What, exactly, is a 240 Volt "assembly"?
A weatherproof box would be needed regardless of the voltage of the outlet....
Now, do you want to surface mount this outlet, or can it be recessed into the structure?
-KB
Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
09-19-2011, 02:22 AM
#3
It will need to be surface mounted. I have installed surface mounted 110v GFI outlets outside, but I am looking for options for a 240v outlet. Currently, I run a long cord inside and plug into my dryer receptacle. I can, however, change the plug type. I only use it once a month for a couple of days.
09-19-2011, 03:32 AM
#4
Semi-Pro Electro-Geek
A 240V receptacle is no different to install, just a different receptacle, wires, and breaker. What's it for?
09-19-2011, 06:53 AM
#5
Licensed electrician
I certainly hope that this is not for a generator backfeed.
09-19-2011, 08:00 AM
#6
Super Moderator
Once a month or so----sounds like an arc welder---good idea to get that outside.
09-19-2011, 08:29 AM
#7
A "Handy Husband"
Jim, that is exactly what I thought when I read this post (next to outside breaker panel?).
What is the use or this 240 volt circuit? The amperage requirement will dictate the type of receptacle you need.
Coastal South Carolina
09-19-2011, 11:49 AM
#8
" Euro " electrician
It is not a huge differnce to do the outdoor receptale for 240 volt device as other say it will affect depending on what the amperage requriement is.
For most stick arc welder I know typically use 50 amp circuit { they useally run about mid 30's amp range } wirefeed welder that will varies a bit ditto with air compressour if you have it as well.
But the major gotcha is the in use cover some may be ok with larger 240 volt device { the plug will be a big question } but there is some of larger in use cover for larger receptales I will find something { for North Américane side } otherwise I know one will click in my mind real quick is Milbank there may be few other items as well.
Merci,
Marc
09-19-2011, 04:17 PM
#9
It will be for a cooler that is on a trailer. It needs to be on a 50 amp breaker.
09-19-2011, 04:24 PM
#10
A "Handy Husband"
If it needs 50 amps, how is it that it works with your 30 amp dyer receptacle? Hate to sound suspicious but sometimes posters try to deke us.
What is the plug configuration of the trailer mounted cooler?
09-19-2011, 06:28 PM
#11
I rent the cooler. The guy installs the plug when he delivers it. I have been using my dryer receptacle, but I want to add a receptacle outside.
I went to one of the big box stores and found what I need.
09-19-2011, 06:29 PM
#12
Can I run 8 gauge wire for a 50 amp receptacle or should I run 6 gauge?
09-19-2011, 06:58 PM
#13
A "Handy Husband"
You need #6 for 50 amp. Also since this is outside you need a weather proof plug and receptacle combination. You also need to know weather this is 120/240 volt (4 wire) or straight 240 volt (3 wire).
09-19-2011, 07:20 PM
#14
Do they make a special receptacle for outdoor applications? I was just going to use a weather proof box and lid. It will be a straight 240 volt application.
09-19-2011, 08:10 PM
#15
Should be fine.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
