240 Volt Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 03:02 PM   #1
240 volt motor
Hello,
When a 240 volt ac compressor motor has the Red wire, T2, showing 120 volts at all times going to the motor, does the Black wire, T1, from the motor have 120 volts showing on a volt meter even though there is an open contact point between the Black wire, T1, and L1 wire that does not allow the other 120 volts to go to the Black wire? Does the 120 volts of the Red line, T2, connect to the Black line, T1, inside the motor?
Thanks and Have a Great Day,
jraquel
jraquel is offline   Reply With Quote
Old 01-10-2011, 03:19 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,262
Yes, you are reading the voltage back-feeding through the motor windings. If you read each motor winding to ground you will see 120 volts, read across the windings and you will have no voltage.
Coastal South Carolina
Old 01-10-2011, 03:23 PM   #3
rditz's Avatar
each Red and Black wire will have 120VAC on them when compared to the neutral, but if you put a volt meter across them will measure 240VAC. this is because they are at opposite phases. your compressor should have two terminals for line voltage and be straight forward to connect. There is no need for a neutral because your compressor does not have any 120VAC loads (such as a light or so forth).
I hope this was helpful
rod
rditz is offline   Reply With Quote
New fan motor going out? DavidI HVAC 5 06-23-2010 10:38 AM
Air Handler Motor Wiring brando1118 HVAC 13 06-18-2010 11:42 AM
240 volt motor robland Electrical 21 10-03-2009 10:34 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 06:30 PM
