Old 09-30-2009, 04:30 PM   #1
240 volt motor
Is there a way to get a 1 phase 240 volt motor to run on 120 current with out using a step up transformer.
robland is offline   Reply With Quote
Old 09-30-2009, 04:49 PM   #2
Tool Geek
PaliBob's Avatar
240 volt motor
No,
Sorry
& Stay Safe
.....Bob Lavery
Old 09-30-2009, 04:52 PM   #3
Code05's Avatar
240 volt motor
Not that I know of . Why is 240 such a problem? What and where is the project?
Code05 is offline   Reply With Quote
Old 09-30-2009, 05:37 PM   #4
It was a dark and stormy
Yoyizit's Avatar
240 volt motor
Run it off your 240v elec. dryer outlet?
Old 09-30-2009, 06:05 PM   #5
Code05's Avatar
240 volt motor
What if it is 25 HP blower motor? Might not hold.
Just kidding.
Old 09-30-2009, 06:08 PM   #6
Yoyizit's Avatar
240 volt motor
Just kidding.
My lights just went out. He probably tried it.
Old 09-30-2009, 06:12 PM   #7
Code05's Avatar
240 volt motor
LOL, I am still laughing.
Old 09-30-2009, 08:59 PM   #8
Wire Chewer
Red Squirrel's Avatar
240 volt motor
It may run, but only at half speed, if less, and it may also be hard on the motor and draw more amps then it should.
I've run a desk fan on a dimmer before, works great. Not really suppose to do that though but I did not know any better as a kid and thought it was cool to be able to control the fan with a dimmer from my bed.
I would just run a 240v circuit though, any reason you don't want to?
Old 09-30-2009, 10:44 PM   #9
nap
You talking to me?
nap's Avatar
240 volt motor
speed in an AC motor is not determined by voltage other than due to an extreme lack of power (horsepower) with the voltage being low, there will be an extreme amount of slippage and resulting from that, lots and lots of heat.
speed is determined by frequency.
Old 09-30-2009, 11:48 PM   #10
240 volt motor
In principle, you should be able to find a VFD (variable frequency drive) that can take a 120 V input and drive a 240 V motor. In practice, I suspect it will be more economical to replace the motor with one intended for a 120 V input.
In grad school I inherited an experiment set up by a previous student. I noticed that pump motor on one the chilled water lines was running rather hot. A commented on it to one of technicians a couple of times about it was told that many motors do run very hot to the touch. After about a year I some how discovered the motor was configured for 240V but connected to 120V (like many motors it could run off both depending on how you make the connection). Correcting this did make it run _much_ cooler. I never did notice any difference in performance though, although I wasn't measuring flow rates or anything.
LanterDan is offline   Reply With Quote
Old 10-01-2009, 01:41 PM   #11
J. V.'s Avatar
240 volt motor
Originally Posted by nap View Post
speed in an AC motor is not determined by voltage,
Speed is determined by the voltage and frequency applied proportionally. This is how a VFD operates.
Example: 1800 RPM motor @460 volts and 60 Hz.
Input 230 volts @ 30Hz = 900 RPM
Input 115 volts @ 15 Hz = 450 RPM
Yes, that would be possible for a short period of time, but not logical and would most likely burn the motor. When using a VFD you size it by input voltage and motor current. If you input 120 volts @ 60 Hz, to a 230 volt motor you are presenting the motor with a severe under voltage situation. Now, lower the Hz to 30 and your motor will run at 1/2 speed and run just fine. I have personally never seen a VFD that could take an input and double it. You can get more voltage out, than you put in, but it will be minimal. Not 230 from 120. But, you can over speed a motor driven with a VFD. You also cannot use a VFD to control speed on a single phase motor. One of the great things you can do is to use a single phase input and output three phase. This is a great function and we use it here all the time.
Most all single and three phase motors are designed to operate at different voltages via the external connections. There will be no operational differences when a motor is connected properly for the voltage available.
Old 10-01-2009, 04:31 PM   #12
240 volt motor
1) You'll note, I began my post with the words "in principle" a VFD could do what the OP wanted, but then suggested another course of action. But I do stand by statement this is entirely possible. Here (http://www.abb-vfd.com/files/manuals...l-Brochure.pdf) you'll note a drive which will happily take a 120V input and output up 240V 3ph. If you can produce 240V 3ph, then in principle you can make drive than produces 240 1 ph.
2) I can't think of any reason why can't have a single phase VFD. In fact I seem to see one here http://www.anaconsystems.com/data/eagledrive11.pdf.
3) If you were going to a VFD, it really would make sense to go with a three phase motor (and one invertor rated), which is probably why you don't see a lot of them designed a single phase one.
4) Its been about five years since I had anything to do with any VFD installations, but I do remember the ABB drives I used to use had a couple of different options in terms of scaling the output voltage with frequency, so its not always quite as simple of halving the frequency and halving the voltage. You are right that they are typically increased and decreased together. I'm sure there are those on this board that can shed much more light on the reasons for this than I care to get into at the moment.
Old 10-01-2009, 06:42 PM   #13
nap
You talking to me?
nap's Avatar
240 volt motor
the frequency is what alters the speed with an AC motor unless you want to consider the slippage caused by a below rating voltage as speed control.
The formula to determine motor speed (without considering slip) is:
120X freq/ number of poles in the motor.
the freq is what determines the speed. The voltage is reduced as the freq is reduced to accommodate the reduced inductive reactance. If you did not reduce the voltage and still reduced the freq, you would smoke the motor due to high(er than designed) currents.
To further support my point, what do you think happens when you run over 60 Hz? You can't increase the voltage but you will still speed up the motor. As a result, you will get an increase in speed but a reduction in HP output so you will have a greater resulting slip so you cannot determine the exact speed simply by calculating the freq and # of poles
Old 10-01-2009, 06:49 PM   #14
nap
You talking to me?
nap's Avatar
240 volt motor
You also cannot use a VFD to control speed on a single phase motor. .
really. I wonder what this is for then:
http://www.anaconsystems.com/text/eagle1.html
certain motor types do not do well on a VFD but there are most definately single phase output VFD's for single phase motors.
Old 10-01-2009, 10:15 PM   #15
Idiot Emeritus
240 volt motor
I've never seen a VFD designed for a single phase motor. I wonder just exactly how they deal with speed regulation when the start switch engages or disengages?
I didn't look at it any too closely, possibly it's designed only for motors without centrifugal start switches. Like PSC type, or A/C compressors, or submersible well pumps. Controlling the speed of these motors would be a cinch.
Interesting.
Rob
micromind is offline   Reply With Quote
Oiling Trane XB1000 AC Fan Motor Build HVAC 5 06-19-2009 05:05 PM
Motor control wiring problem dgr68 Electrical 8 01-04-2009 06:13 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 07:30 PM
