240 Vac To 208 Vac - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-18-2008, 11:28 AM   #16
Rewards Points: 1,512
If the kiln has variable temperature settings not accomplished by switching more or fewer heating elements in at full voltage, then I would run it directly from 240 volts but never use the maximum setting.
Such alternative temperature selection can be accomplished by putting elements in different series/parallel combinations, or by using rheostats.
Old 11-18-2008, 11:47 AM   #17
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
My opinion is put the kiln on a buck/boost as mentioned by kbsparky or E-Bay.
Btw... if you keep it... kilns are considered continuous loads and the wiring will need to be sized accordingly.
