#1 |
240 v Space heater plug?
I added my 30 amp breaker and outlet. Now, The plug I have on the space heater now (240 volts, 20 amp) needs to be replaced. Can I just add a 30 amp plug? What do I do about the chord? Do I need a new one or can I just add the new 30 amp plug to replace the old 20 amp plug? I've heard about 5 different answers from electricians. I'm wondering if I should've just kept the plug as it was and went with a 20 amp outlet. Problem is the heater draws 16.7 amps, which is why I went with the 30 amp breaker to avoid the surge issue and being above the magic 80% of the load. By the way, the heater is 4000 w. Just want to make sure I'm doing this right. I really am frustrated that so many electricians have different answers. Thanks!
#2 |
Electrical Contractor
If the heater came equipped with a 20 Amp plug, then you need to install a 20 amp receptacle.
![]() I'd guess you need a NEMA 6-20R. ![]() Change the outlet to match the heater, and install a 20 Amp breaker. Otherwise, you most likely will void any warranty on the unit, and violate any UL listing as well.
#3 |
Well, I agree with kb. Now you have heard from two that tell you the same thing!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#4 |
Licensed Pro
Make that three...
"Life is hard. Life is harder when you're stupid." John Wayne |
#5 |
Not an electrician, but I agree, you should change the receptacle and breaker.
#6 |
UAW SKILLED TRADES
I also agree. Where your getting your misinformation is the 80% rule. If your heater plugs into a individual single receptacle dedicated to that heater then you can run that branch circuit at 100% of its rating as long as the load is not continuous. A cord and plug heater is not a continuous load. The 80% rule has to do with cord and plug equipment, appliances, etc.. that are used on general purpose branch circuits that serve more than one outlet. A duplex receptacle is 2 outlets. In this case your not supposed to plug anything into one of those outlets that exceeds 80% of a branch circuits rating. For a 20 amp branch circuit that would be 16 amps. But there is no way to control what people plug into multiple receptacles on a branch circuit this is just the code requirement.
" One nice thing about the NEC articles ... you have lots of choices" Stubbie |
#7 |
Idiot Emeritus
Even though 4000 watts at 240 volts is 16.67 amps and is, at times, a technical code violation to supply with a 20 amp circuit, I can't even think of how many times I've done exactly that. Most of my work is inspected, and I've never been busted for it.
In reality, a 20 amp circuit will run a 4000 watt load for a long, long time. Completely safely. Rob |
#8 |
UAW SKILLED TRADES
I concur (but I don't agree....
) if I do.. then the internet police will put us both in jail.
#9 |
Xtreme DIY'r
So, no-one saying that they should absolutely NOT put this on 30a ?
#10 |
You should not plug a NEMA 6-20P into a 30 Amp circuit.
#11 |
Xtreme DIY'r
Woops - missed that
Everyone basically did say not to use the 30a breaker
#12 |
Any 20 amp receptacle or plug on a 30 amp circuit is a no-no.
| Display Modes | |
| Cape Cod Style House Attic/Crawl Space Insulation Help | Danielg | Insulation | 24 | 05-21-2012 09:20 AM |
| Baseboard Heater: Can I wire it to plug into an AC recepticle? | JBiz | Electrical | 3 | 12-01-2007 09:42 AM |
| How to Space Water Heater Flue Vent from Outside Wall? | austinbirdman | Plumbing | 1 | 03-12-2007 11:28 AM |
| Space Heater And K-1 Kerosene | bobo | General Discussion | 7 | 10-25-2006 11:38 PM |
