240 V Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-08-2011, 12:09 AM   #16
Rewards Points: 512
Mulltron, you're trying to balance the phases, and that's good, but I don't think it's a big concern here. The pros can correct me if I'm wrong.
I'd simply run #8 between the panels, from a 50a Double Pole Breaker at the MAIN to the subpanel. Then, you can wire your subpanel branch circuits as needed.
In order to balance the phases, if that's what your concerned about, understand that as you add branch circuit breakers down one side of the panel, each breaker is automatically placed on the opposite phase (or Hot Bus) as the one before it, so that (in a 10 circuit panel, for example) 1, 5 & 9 are on the same bus, while 2, 6 & 10 are on the other. In a 10 circuit panel, 1, 5, 9, 4, 8 would be on one bus, while 3, 7, 2, 6 & 10 would be on the opposite.
I won't address the the advantages of 240 vs 120 except to say almost everyone provides a subpanel (for general lighting/load) with 120/240 so that they can run both 120 and 240 volt devices.
Hope this helps.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
