240 V Breaker Switch-many Colours! - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2015, 10:55 PM   #1
Rewards Points: 4
240 v breaker switch-many colours!
I would really appreciate help on this, I was attempting to change an old breaker have taken out all wires and removed old breaker, now I cant remember which way the wires went in
there four wires
two yellow
one blue
one brown
it effect dishwasher and and two outlets.
is it possible for someone to tell me how to re-wire this? I feel like im halfway there!lol
thanks very much in advance
Hassan.ghavam is offline   Reply With Quote
Old 06-25-2015, 11:45 PM   #2
Rewards Points: 104
What country are you in? And why do you think/want to change the breaker?
jreagan is online now   Reply With Quote
Old 06-26-2015, 12:25 AM   #3
Retired from the grind
gregzoll's Avatar
Rewards Points: 3,832
That is a Double Pole, Double Throw Circuit Breaker. The two inner screws as you see on the graphic are for one 240 Volt circuit. The outer two can either be used by two different 120 Volt branches, or another 240 Volt circuit, but you would need the handle tie to allow those two to trip at the same time for use as a second 240 Volt circuit.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 06-26-2015, 12:26 AM   #4
gregzoll's Avatar
I am thinking European from how small those wires are in the background.
Old 06-26-2015, 02:46 AM   #5
Electrician
Rewards Points: 3,242
This is without a doubt either in the US, Mexico or Canada. You will not find white used as a neutral in Europe, 120/240 split phase power or UL listed plug in breakers (DIN rail systems with a CE listing are employed instead).
The separate colors don't indicate anything. The NEC does not have a color code requirement other then green or bare be ground and white or grey be neutral for applications like this so the electrician can use any color he chooses for his hot wires.
Anyway to address the OP's predicament.
Chances are the two yellow wires are for the 240 volt circuit which will go to the breaker's two center screws. The brown and blue will go to either outer poles, but you might have to swap them after testing what they power since you might get something different from the panel directory.
This of course is ASSUMING that the two yellow wires are your 240 volt circuit, but chances are it is safe to assume yes.
The only way to know for sure is to trace the circuit.
Jump-start is online now   Reply With Quote
The Following User Says Thank You to Jump-start For This Useful Post:
Jim Port (06-26-2015)
Old 06-26-2015, 05:28 AM   #6
Master Electrician
Rewards Points: 592
That is not a double-pole, double-throw circuit breaker. There are double-pole, double-throw switches that would connect two poles to two different loads, a transfer switch is a common example of a double-pole, double-throw switch. I've never seen a DPDT circuit breaker. The CB shown is a quadplex breaker. It is really two double-pole circuit breakers that fit on a single pair of bus stabs. See image below for DPDT switch, and it is not what that CB does:
Greg being wrong, once again.
Mark
Licensed Master Electrician
Commonwealth of Virginia
busman is offline   Reply With Quote
The Following 6 Users Say Thank You to busman For This Useful Post:
Jim Port (06-26-2015), Jump-start (06-26-2015), mm11 (06-26-2015), mpoulton (06-26-2015), Speedy Petey (06-26-2015), stickboy1375 (06-27-2015)
Old 06-26-2015, 08:47 AM   #7
Rewards Points: 4
Thanks a lot for the reply's , I'm from Canada. The breaker keeps tripping, when I use the microwave. I switched out the microwave and still same issue, so I thought I would try changing the breaker. I Think I'm going to try Jump-start's suggestion?... I attached a pic of the service panel.
Old 06-26-2015, 09:10 AM   #8
Master Electrician
Rewards Points: 592
There is no way to tell you how this should be wired from the photos, but you need to be very careful; you may have a 240V or multiwire branch circuit involved here and getting the right wires to the right terminals will be critical. Even if everything comes on and works, it might burn up down the road if it is a MWBC.
Mark
The Following 3 Users Say Thank You to busman For This Useful Post:
Jim Port (06-26-2015), mpoulton (06-26-2015), stickboy1375 (06-27-2015)
Old 06-26-2015, 11:59 AM   #9
gregzoll's Avatar
Could just be a bad outlet or someone added more outlets than allowed to that branch circuit.
Is the outlet a GFCI or conventional outlet? How many watts are the Microwaves?
Old 06-26-2015, 01:29 PM   #10
Electron Plumber
Rewards Points: 1,558
Stop. Just stop.
The Following 5 Users Say Thank You to InPhase277 For This Useful Post:
busman (06-26-2015), Jim Port (06-26-2015), Jump-start (06-27-2015), sgip2000 (06-26-2015), stickboy1375 (06-27-2015)
Old 06-26-2015, 02:53 PM   #11
Electrician
Can you post a pic of the top left side where the slot is currently open? I see what looks like a brown spot? Maybe its just the picture.
Old 06-26-2015, 04:06 PM   #12
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 592
What is on when it trips? Could be that there is too much on the circuit and the breaker is doing it's job. From the looks of it I highly doubt the breaker is bad.
Also, what is that single-pole 30 breaker for on the bottom left??? Every time I see on of them I get suspicious.
Answers based on the 2008 & 2011 NEC.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
gregzoll (06-26-2015)
Old 06-26-2015, 11:38 PM   #13
gregzoll's Avatar
Petey, does that look like a burn mark to you on the Upper Left part of the Busbar?
Old 06-27-2015, 06:55 AM   #14
Rewards Points: 592
It certainly does, but I don't think that was from heat. It looks like someone got blowed up.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
gregzoll (06-28-2015), mpoulton (06-28-2015)
Old 06-27-2015, 08:13 AM   #15
Licensed electrician
Rewards Points: 3,458
What is all over the handles on the bottom left breakers? Caulk.?
Turning light switch off kicks breaker Bobthejester Electrical 5 04-17-2013 07:22 AM
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
3 way switch layout has me confused crescere Electrical 5 09-08-2012 10:26 AM
Light Switch Breaker Trip kremic30 Electrical 11 02-17-2012 06:55 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
