240 Table Saw In Middle Of Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 11-05-2009, 07:01 AM   #1
Rewards Points: 160
240 table saw in middle of garage
options? I'm running it now at 120v but all the 120v outlets are on same circuit as the garage lights and breaker trips frequently. There's a 240 outlet (originally for a welder) but it's 15-20 ft away. Can I drop something retractable from the ceiling? Floor is poured slab so adding an outlet in it would be a lot of work. Thanks.
philS is offline   Reply With Quote
Old 11-05-2009, 07:45 AM   #2
Yup they have retractable outlets
You just need tomake sure it is rated for the saw
And that it doesn't have too much wire as that will cause voltage drop
Old 11-05-2009, 09:35 AM   #3
47_47's Avatar
Rewards Points: 86
Need more information. Wire size and breaker of the welder outlet. Table saw motor amps and voltage. Check out a cable guard system similar to this:
http://www.checkersindustrial.com/pr...FQYMDQodwE1zJQ
47_47 is online now   Reply With Quote
Old 11-05-2009, 11:32 AM   #4
Rewards Points: 356
Are you sure you want the power cord coming down from the ceiling? You likely put the saw in the middle of the garage so you could work all the way around the saw. A power cord from the ceiling will be in the way more often than you think.
Rege
RegeSullivan is offline   Reply With Quote
Old 11-05-2009, 11:46 AM   #5
Rewards Points: 160
I'm away from town now but it's a Delta "contractor's saw". The current ones are 1.5 HP. Nor do I remember what amps the existing 240 outlet is - from my recollection of the cable it's 30A.
But the floor "guard" system might work fine regardless.
As for the retractable, the one in the picture looks to me to be 120V. Are there 240V (say 20 A) ones sold in US? I Googled "240V retractable" and got nothing useful.
I suppose even if I just wired a ceiling outlet from a different 120V circuit than the lights, and then used a 120V 12 gauge retractable with a short cord, it'd help.
Old 11-05-2009, 12:18 PM   #6
47_47's Avatar
Rewards Points: 86
You saw will perform better at 240 volts. I would try and use the existing welder outlet circuit to power your saw, if the wire is suitable. You may have to change the breaker and receptical to 15 amp @240 volt.
Old 11-05-2009, 03:09 PM   #7
Child Alert! Pull Up!
fltdek's Avatar
For the cost of a new 20A breaker, you could easily convert that 240V outlet to a 20A 120V outlet, assuming thats 12/2 that feeds that circuit, then you would have a dedicated circuit for your saw.
fltdek is offline   Reply With Quote
Old 11-05-2009, 04:56 PM   #8
Rewards Points: 160
Rege -- Duh....good point! So I'll go with 47's floor guard system.
47 -- Yup, that's why I want it on 240 V. It won't bog down ripping 2x wet DF or any sort of hardwood and will be both faster and safer. But why 15 A as opposed to 20A or even 30 if the receptacle is currently wired 10-2 + g? Seems to me I've read a bunch of threads on this exact same issue but I don't know what I'd search for.
And is a 240V extension cord legal? I know it's not for a 240V appliance but a shop tool isn't an appliance -- or is it? Ah, duh ... just put a longer cord on the saw with the right cord cap!
Old 11-05-2009, 05:05 PM   #9
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
run metal conduit across the floor with a box for a recep at the end to plug in to. Run it to the panel or to a junction box and then NM from there to the panel if legal.
attach the conduit to the floor with one or two hole straps and tapcon concrete screws or some other form of solid and sturdy attachement.
Old 11-05-2009, 05:25 PM   #10
I have a ceiling outlet tapped off of old HVAC cabling. It works for me.
Old 11-05-2009, 06:44 PM   #11
Rewards Points: 160
nap -- Naah. I think even 1/2" emt on floor would be a trip hazard and there's no reason to wire a new circuit when I've already got 240 to the garage. Besides, the panel is a pain to get to and it's a full SqD QO which means buying another tandem which is spendy.
Yoyizit - I may still consider it but rege's point about a drop cord getting in the way makes sense to me.
Unless someone explains why I need to use a 15 A receptacle, I'll use a 20A 240V recep and a 20A breaker and rig a new 12 gauge cord that I'll run through some brand of floor guard.
Thanks for the input!
Old 11-05-2009, 06:47 PM   #12
Idiot Emeritus
Rewards Points: 1,492
Code-wise, there's nothing I know of that prevents the use of a 240 volt extension cord. We use them on a very regular basis on construction jobs as temporary power feeds. Some of the industrial places I work at have 480 volt 3 phase extension cords. Just make sure to use a 250 volt receptacle and plug.
Code-wise, the maximum circuit size for a 2 HP single phase motor operating at 240 volts is 30 amps. If it's 1-1/2 HP, the maximum is 25 amps.
Rob
P.S. You'll notice considerably more power if the saw is operated at 240 volts. In theory, there's no difference. In reality, there's quite a difference.
micromind is offline   Reply With Quote
Old 11-05-2009, 07:02 PM   #13
Re-wire the saw with some heavy duty 10-3 SOOW wire so you can reach that 240 outlet. That way you can coil it up after use.
naehring2000 is offline   Reply With Quote
Old 11-05-2009, 08:07 PM   #14
You have a link?
I'm wondering if they follow the 125v Grainger rules; #14 and larger, 15A
and max. voltage drop @ rated current = 3%.
Old 11-05-2009, 08:29 PM   #15
nap
You talking to me?
nap's Avatar
I noticed you said "temporary" several times and that is the key word.
We are talking about a permanent install and an extension cord is not code compliant. PLUS if you use a cord, it is to be GFCI protected and unless you have a cheap and easy access to a 240 volt GFCI, that would also put a stop to the extension cord.
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 08:47 AM
