240 Requirement For Hot Tub - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 12:56 PM   #16
" Euro " electrician
frenchelectrican's Avatar
If that hot tub mention 4 conductor then you have to bring it out to the hot tub but becarefull with conductor slection the codes do not allow bare ground conductor.
So therefore you can put the spa subpanel { typically will included a two pole GFCI breaker in there } and run pvc conduit or flexiable plastique conduit { if your area do allow it } and run THHN/THWN conductors ( Black . Red . White et Green )
Merci,
Marc
GFI outlet requirement ninghai HVAC 2 06-27-2011 06:34 PM
Compost or top soil requirement cprao Landscaping & Lawn Care 10 12-28-2010 06:01 PM
2008 NEC Clearance Requirement vs. Gas Meter cctxcc Electrical 7 07-17-2010 08:10 AM
Panel Upgrade space requirement joshvette001 Electrical 4 05-02-2010 05:48 PM
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 03:57 PM
