240 Requirement For Hot Tub - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 12:23 PM   #1
240 requirement for Hot tub
Looking for insight. I helped my neighbor dis connect a hot tub to be replaced by new hot tub. This consisted of two hot wires and ground. (240 volt). I replace the wiring into new hot tub and everything is fine.
What puzzles me is both new and old tubs required 4 wire install but there was only 3. The 4 wire was balck, red (hot) green and white(netural) but there is no white coming from house. How does the circulation pump and ozone (110v) gets its netural if there is no netural coming in from house?
brad c is offline   Reply With Quote
Old 07-26-2011, 12:28 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 152
My guess would be they are using the ground wire., or there could be a transformer.
If it does not have a transformer, stay out of the tub!!!!!
Old 07-26-2011, 12:31 PM   #3
There is a transformer. So I am guessing that the 110 netural requirement is getting the feed from transformer?
Old 07-26-2011, 03:59 PM   #4
Yes, one leg of the low side of the transformer will be grounded and they are using that for the neutral.
CheapCharlie is offline   Reply With Quote
Old 07-26-2011, 04:18 PM   #5
Thanks for the reply. Not sure I understand how ground and netural can be mixed as you suggest.
Old 07-26-2011, 04:38 PM   #6
Here's a pic. Same reason why your neutral bar is bonded to your main tub with a bonding strap (neutral tied to ground)
Old 07-26-2011, 04:42 PM   #7
thanks!!!!!
Old 07-26-2011, 04:50 PM   #8
Rewards Points: 324
Are you saying that the documentation on the Hot Tub stated it was required, but you didn't supply it ? If so I think that's a problem. My Tub clearly state it only need two hots and a ground. Just asking -
tribe_fan is online now   Reply With Quote
The Following User Says Thank You to tribe_fan For This Useful Post:
brad c (07-26-2011)
Old 07-26-2011, 05:02 PM   #9
The documentation did state 4 wires - black, red (the 2 hots, white - netural and green - ground.
But the installation was only the black red and green and some how had nuteral w/o a netural coming in.
Old 07-26-2011, 05:14 PM   #10
Lic Elect/Inspector/CPO
spa mfg Model number would be helpful. If the mfg says 4 wires are needed than it needs to be wired that way.
NJMarine is offline   Reply With Quote
Old 07-26-2011, 05:21 PM   #11
biggles's Avatar
neutral/white is considered an electrical ground and a green is a mechanical ground..amperage is traveling on that ground wire back to the CB panel. if you disconnect that green with a load it will arc,and the load will shut off.they never run a white neutral with 240V unless spec'd by the installer not the product people
Old 07-26-2011, 05:54 PM   #12
Saratoga Pavillion - 1998-99 model with a SAR200 control board
Old 07-26-2011, 07:07 PM   #13
Rewards Points: 324
If this is your model - then you need 4 wires.
http://www.saratogaspas.com/download...s%20Manual.pdf
Old 07-26-2011, 07:27 PM   #14
Yes you need 4 wires as well as being protected by gfic. I install spa panels which is cheaper than just buying a 50 amp gfic by itself.
Old 07-27-2011, 08:33 AM   #15
Tribe fan, I do have that manual and I do agree with you. I am only stating how this was wired at my neighbors and how I attemptes to do the same at my house, which lead me down this road of trying to understand how you can get netueal w/o a netural fromk GFI outside box.
NJ Marine is there a way i can contact you?
GFI outlet requirement ninghai HVAC 2 06-27-2011 06:34 PM
Compost or top soil requirement cprao Landscaping & Lawn Care 10 12-28-2010 06:01 PM
2008 NEC Clearance Requirement vs. Gas Meter cctxcc Electrical 7 07-17-2010 08:10 AM
Panel Upgrade space requirement joshvette001 Electrical 4 05-02-2010 05:48 PM
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 03:57 PM
