Closed Thread
Old 12-21-2010, 02:45 PM   #1
240 pooltimer, want to run 110v plug for stero
Hey guys i need some help. i have a 220 intermatic pool timer. it runs 2 hots and 1 ground. Is there anyway that i could use 12g yellow romex to run a 110 plug that would obviously have to run 24 hours because i'll have no timer to it. i dont want to have to run a line from the main breaker just for a plug. i've seen a 110v ran off a 220v timer i just cant remember the wiring. but i do remember if i do run a 110 off the 220v taht i would have no way of turnin it on or off, it would be live 24hours. heres a layout of intermatic timer- A-neutral and 4-lines line-1 has the first hot wire. line-2-white water pump line line-3-hot black wire...4-black wire from pump... the problem i have is not haveing a neutral. how can i make a neurtal for the black or white wire? some one suggested running 1-white wire to the plug, and the extra black wire to the ground but im skeptical of that. i know i cant connect it to the black-line 4 because it will be another 240 plug. if i can run a 110 that will be live 24 hours i dont mind not being able to turn it on or off, it wont be used much. thanks guys if anyone could help
chicanobear is offline
Old 12-21-2010, 02:53 PM   #2
Xtreme DIY'r
Do you have a neutral going from the breaker to the timer ?
If you don't have a neutral you can't setup 120v
Scuba_Dave is offline
Old 12-21-2010, 02:55 PM   #3
Electrical Contractor
Without a neutral, you can't get a 120v receptacle.
I would run a new line from the panel, and be safe.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now
Old 12-21-2010, 02:59 PM   #4
what if i were to buy a 110v pool timer, is there anyway i could then wire it off the 240'v timer to run 110.? i know this is possible i just wanted to save money and not have to buy a 110n timer. could you explain how i could pull 110v from the 240. so there is no way that i could make a neutral? im confident, if there is any tricks i will do it. im capable of taking instruction well.
Old 12-21-2010, 03:06 PM   #5
Unless you want to replace the pumps to 120v, you can't change the timer.
jbfan is online now
The Following User Says Thank You to jbfan For This Useful Post:
chicanobear (12-21-2010)
Old 12-21-2010, 03:10 PM   #6
Seasoned DIYer
If you are willing to use a stereo that uses an AC adapter, many adapters are rated 96-264v. Even some direct plug in devices have international spec power supply built in. My 32" LCD TV for example has a 96-264v power supply.
HVAC_NW is offline
Old 12-21-2010, 03:11 PM   #7
Xtreme DIY'r
There isn't any trick to make a neutral where one does not exist
You need to run another wire or convert the existing wire totally to 120v
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Old 12-21-2010, 04:26 PM   #8
Maybe the OP just needs a battery-powered radio, lol.
clashley is offline
Old 12-21-2010, 04:49 PM   #9
An old Tradesmen
We don't aid in unsafe acts.
As far as how dangerous is it. Dangerous enough to kill someone.
Thread closed.
beenthere is offline
Closed Thread
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 08:48 AM
Replacement plug for an old box freezer brich Electrical 1 05-11-2010 07:44 AM
removed old romex (added new wire) and added a plug doesn't work now? Limit54 Electrical 9 11-08-2009 10:03 PM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 10:49 AM
20 amp plug MikeyP Electrical 6 01-03-2009 10:04 PM
