240 Outlet To Welder - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2011, 07:32 PM   #1
240 outlet to welder
I acquired an old 30-200 Craftsman welder. I have 240/50 amp service in my garage. My garage service is 3 wire (black/red/white). The old plug on the welder is 3 wire (black/white/green).
I need to rewire a new male plug on my welder.
I know black (service) to black (welder). I assume white (service) to green (welder). I guess red (service) to white (welder).
Guidance please.
Thanks.
Chris
Chris D. is offline   Reply With Quote
Old 04-13-2011, 08:18 PM   #2
dSilanskas's Avatar
Wow you scare me with your guess... Let me help you out its easy.
Black to black
White to white
Bare copper to Green
Cap the Red you don't need it....
dSilanskas is offline   Reply With Quote
Old 04-13-2011, 08:26 PM   #3
Black to black
White to white
Thanks for the quick response.
I can do black to black and white to white but...I don't have any bare copper. A total of 3 wire in my garage service: black/red/white, no ground. As I previously mentioned, the old plug on the welder also has 3 wires total: black/white/green.
I still need some guidance.
Thanks.
Chris
Old 04-13-2011, 08:34 PM   #4
dSilanskas's Avatar
So in the panel itself there is no bare wire?
Old 04-13-2011, 08:53 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Black to black
White to white
Sorry, but this reply is similarly scary.
The way you are describing will give him a 120v feed to a 240v welder.
His original description is almost right.
Old 04-13-2011, 08:54 PM   #6
OK, clear this up. WHAT is a "service" in your eyes?
Is this simply a receptacle? Or is this feeing a sub-panel?
Old 04-13-2011, 09:30 PM   #7
I opened up the panel and the ground had not been wired to the service outlet. I did the black/black, white/white, ground/ground and capped the red.
Thank you very much for the guidance and patience.
Chris
Old 04-13-2011, 09:32 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,864
Black to black
White to white
To second what Speedy Petey said, this is completely wrong, and not even possible given the arrangement he described (there is no "bare copper" to connect to). His original guess is fine.
The welder is using black and white as the two hot conductors for a 240V circuit. That means the white connects to the house's red conductor.
The green can connect to the house's white conductor for grounding, just like an old fashioned dryer. Unlike an old fashioned 3-wire dryer, there is no hazard presented by that since the welder doesn't use that conductor as a return for 120V loads.
mpoulton is offline   Reply With Quote
Old 04-14-2011, 04:04 PM   #9
So I guess it works. Awesome.
Switched Outlet Issue mjm Electrical 13 06-14-2015 08:56 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Welder outlet question coyote556 Electrical 4 12-03-2007 04:30 PM
adding 20amp outlet for for welder Geophile Electrical 12 05-03-2007 09:17 PM
