240/208 Heater Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-19-2005, 09:28 PM   #1
Send a message via Yahoo to fburke
240/208 Heater wiring Question
I have a Dimplex single element heater with fan I am installing in a bathroom. It is the 208/240v model.
In looking at the diagram it does not make any reference to a neutral. It shows L1 and L2 and only mentions a neutral for the 120v modal and you would wire it to the L2 terminal.
I have ran a new 20A circuit using 12/3 romex. Do I need to hook the neutral to anything and just use the red black and ground? Should I just cap off the white??
I would think the motor for the fan would need it but that is rated for 240/208 also.
Thanks for any help
fburke is offline   Reply With Quote
Old 06-20-2005, 07:30 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
If it is a straight 208/240 then it would not need a neutral, just 2 hots and a ground. I would cap the white and not use it.
Old 06-20-2005, 01:09 PM   #3
Thank you! that is exactly what i did and it works fine.
wiring diagram question screenporch21 Electrical 10 11-30-2008 09:14 PM
3-Way Switch Wiring Question bhpizza Electrical 4 08-07-2007 06:51 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 10:40 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
