240/208 Convection Wall Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2011, 11:27 AM   #1
240/208 convection wall heater
would like to know how to wire it. it was taken from one room an is going to be installed into another room so its already hooked up to a breaker. it has a red and a blue wire in the back. it also needs to be hooked up to a thermostat.
Mike Marshall is offline   Reply With Quote
Old 09-22-2011, 12:25 PM   #2
Rewards Points: 1,536
Run cable to new thermostat location. Run cable from there to new heater location.
Nowadays electric heaters use 2 pole thermostats (that switch off both wires of the incoming cable. Be sure to get the thermostat wires correct, connect the incoming power cable to the "line" side thermostat wires or terminals and connect the cable to the heater to the "load" side thermostat wires or terminals.
If you run the new wires starting at the old heater location there must be a junction box for the wires with exposed cover at that location.
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Electric Wall Heater Shield JTee Electrical 1 02-13-2011 12:35 AM
Correct gauge wire on wall heater?? Master Brian Electrical 4 11-16-2010 01:48 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Lear Siegler Wall Heater back clearance Steve Burke HVAC 4 09-19-2009 04:22 PM
