24 Volt AC Wiring In Same Conduit As 220 Volt Single Phase And In Same Outdoor Enclosure As 220 V Silgle Phase And 3 Phase - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2012, 08:41 AM   #1
24 volt AC wiring in same conduit as 220 volt single phase and in same outdoor enclosure as 220 v silgle phase and 3 phase
I have an electricall contractor that ran my 24 volt controll wires for AC systems in the same conduit as 220 volt power. I understand that if they are the same insulation its ok but it is not the best practice more over they ram two sources of 220 single phase one source of 3 phase and 3 sources of 24 volt control in the same junction box outside.
Whan my Heat pump goes into defrost it fries the defrost board this has happened atlest 4 times with some transformers aswell.
I keep requesting they separate my 24 volt control wiring from all high volt and they keep saying it sok to do this.
We even ran a temporary thermostat wire outside of conduits and systems ran fine. They removed my t stat wire and hooked their wires back in and we started to fry boerds again
We even contacted the manufacturer and they said they do not want 24 volt controll wires in the same conduit and high voltage but the Electrical contractor will not bugde its been over a year and a half
What can I do
arbailey is offline   Reply With Quote
Old 05-24-2012, 09:01 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
You might have to bite the bullet and get someone to pull the wires out.
Who has been paying for the boards and labor?
Old 05-24-2012, 11:35 AM   #3
Idiot Emeritus
Rewards Points: 1,492
I've run tons of 24 in the same conduit as 480.
n my experience, if the 24 goes to electromechanical devices (like relays) it'll be ok. If it goes to electronic devices, it might be ok, but a lot of cheap boards (like most HVAC) will have trouble.
One possibility is to pull shielded cable for the 24 in the same conduit as the higher voltage stuff.
Rob
P.S. Ground the shield at one end only, never both ends.
micromind is offline   Reply With Quote
The Following User Says Thank You to micromind For This Useful Post:
andrew79 (05-24-2012)
Old 05-24-2012, 07:34 PM   #4
Master Electrician
generally it's a dumb idea, legally you can do it but all boxes need to be identified as having two voltages in them. As the previous poster says running a shielded cable will probably solve your problem but it's still a sketchy install.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 05-24-2012, 07:38 PM   #5
Rewards Points: 776
It is legal but once you commingle LV with 120v don't you have to use 600v insulation? That seems to push you to more expensive bulkier wire and undermines the benefit.
curiousB is offline   Reply With Quote
Old 05-24-2012, 09:43 PM   #6
Idiot Emeritus
All conductors need to be rated for the highest voltage in the conduit.
If there's 24, 120 and 240, nothing can be rated less than 240.
There's plenty of 300 volt wire available that's less bulky than 600.
Older 220 Volt Single Phase Air Compressor wiring larry krejci Appliances 1 11-16-2011 04:43 PM
heating element 240 volt single phase geeyathink Electrical 19 02-20-2011 07:57 AM
Wiring Single Phase through 3 Phase socket tonyr417 Electrical 10 10-26-2010 10:09 PM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 04:46 PM
How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase wantsomegetsome Electrical 9 05-04-2009 11:49 AM
