2340 Ingersol Rand Air Compressor - Electrical - DIY Chatroom Home Improvement Forum
Old 07-16-2013, 02:25 PM   #1
2340 ingersol rand air compressor
how to wire 2340 ingersol rand air compressor
pellerin6 is offline   Reply With Quote
Old 07-16-2013, 03:08 PM   #2
Oso954's Avatar
Rewards Points: 1,338
From the instructions:
WARNING
Electrical installation and service should be
performed by a qualified electrician who is familiar
with all applicable local, state and federal laws and
regulations.
Oso954 is online now   Reply With Quote
Old 07-16-2013, 09:32 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,970
The product manual says to use #8 wire, and refers you to the NEC for overcurrent protection sizing. So you'll need to do that. This is probably not a DIY project for you if you're starting from the question of "how to wire 2340 ingersol rand air compressor." You will need to run a new dedicated circuit from your panel, and do it safely and properly.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 07-16-2013, 10:40 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Before I can comment more on this one .,
Is this moteur is single phase or triphase moteur ?? that will make the differnce on that situation of wiring it up properly.
If triphase moteur then need to know what supply voltage it is.
Merci,
Marc
Air Compressor Fittings - Differences? roasted Tools 3 09-19-2012 08:15 PM
3 phase 230/460 air compressor install questions DinAZ Electrical 7 10-21-2011 10:28 PM
Help assembling compressor jfhspike Tools 5 03-27-2011 10:07 AM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
