-   -   2340 ingersol rand air compressor (http://www.diychatroom.com/f18/2340-ingersol-rand-air-compressor-183710/)
pellerin6 07-16-2013 02:25 PM
how to wire 2340 ingersol rand air compressor
Oso954 07-16-2013 03:08 PM
From the instructions:
WARNING
Electrical installation and service should be
performed by a qualified electrician who is familiar
with all applicable local, state and federal laws and
regulations.
mpoulton 07-16-2013 09:32 PM
The product manual says to use #8 wire, and refers you to the NEC for overcurrent protection sizing. So you'll need to do that. This is probably not a DIY project for you if you're starting from the question of "how to wire 2340 ingersol rand air compressor." You will need to run a new dedicated circuit from your panel, and do it safely and properly.
frenchelectrican 07-16-2013 10:40 PM
Before I can comment more on this one .,
Is this moteur is single phase or triphase moteur ?? that will make the differnce on that situation of wiring it up properly.
If triphase moteur then need to know what supply voltage it is.
Merci,
Marc
