Old 02-16-2009, 11:38 AM   #1
230V motor
I have machine with a motor that says 230V, 13 A, single phase. can I connect this to my electric dryer outlet?
samnoa is offline   Reply With Quote
Old 02-16-2009, 05:02 PM   #2
Electrician
ctsmiths's Avatar
230V motor
As long as its rated for the amp draw the motor has I cant see why it would be a problem, though it isnt common practice
ctsmiths is offline   Reply With Quote
Old 02-16-2009, 08:47 PM   #3
Idiot Emeritus
230V motor
Indeed you can. If the outlet is 4 wire, use only the two hots and ground, not the neutral.
Rob
micromind is offline   Reply With Quote
Motor control wiring problem dgr68 Electrical 8 01-04-2009 06:13 PM
Air Compressor Motor Hums, Trips Breaker pointertopica HVAC 10 12-02-2008 11:20 PM
Goodman motor availability NomadTrash HVAC 5 11-08-2008 12:01 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 07:30 PM
Blower Motor Wiring Help atvguy64 Electrical 7 02-04-2008 12:39 AM
