230v Appliaces Only Seeing 7v - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2007, 11:50 AM   #1
Ouch! That was my thumb!
230v appliaces only seeing 7v
Let me apologize in advance if my terminalolgy is a bit off. I'm a mechanical engineer that only had to take 1 electrical class in school so I have very little knowledge of this subject. I have an issue at my breaker box where the two main lines come in from the ground. I traced it back to the breaker box from my heating system which is no longer working. When the heating system was probed, it read only 7v but should see 230. So i know that the heating system isn't broken. My other appliances such as the oven and dryer are also no working.
The strange thing is that all the other outlets and switches in the house that are 115v are working just fine. I probed the breaker box and each of the single switches see 115v, as expected. I probed each of the two main lines coming in and they each see 115v. but when i probe across the two, I only see 7v. I should see 230v.
my big question is what to do. is this a problem considered inside the house and I'd have to get an electrician, or is it a problem with the source power and I'd get the electrical company out here to fix it.
thanks
toolmanwannabe is offline   Reply With Quote
Old 02-14-2007, 04:38 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
Are you sure you are getting 115 on each leg of the incoming wire.
Are you measuring to ground? If you are not getting 240 across both legs, then you are missing a hot leg. Most of the time it is a power company problem.
Call them.
Old 02-14-2007, 07:47 PM   #3
Rewards Points: 150
did you try measuring it at the breaker box?
elementx440 is offline   Reply With Quote
Old 02-15-2007, 12:49 AM   #4
I have seen the symptoms you are describing only once before. It turned out to be the meter was bad. Don't ask me how that could cause those symptoms but the PoCo told me that was what was wrong.
geeyathink is offline   Reply With Quote
Old 02-15-2007, 02:17 AM   #5
Rewards Points: 150
Old 02-15-2007, 03:35 PM   #6
Electrical contractor
RobertWilber's Avatar
7 volts?
not two phases ...
center tapped single-phase 120/240-volt transformer
call the power company
RobertWilber is offline   Reply With Quote
208v, 230v, 240v Whats the difference? BJinaTJ Electrical 7 12-19-2006 09:56 PM
Installing a 230v outlet ThePlumber Electrical 7 07-15-2006 11:16 AM
