230v 50hz Light Switch In A 230v 60hz Country - Electrical - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 10:06 AM   #1
230v 50hz light switch in a 230v 60hz country
I'm looking to buy and install this IR remote light switch that's rated for use in the UK / EU. And I know that they use 230v 50hz over there. But over here in the Philippines, we have the same 230v but we use 60hz frequency. Would this be a major problem?
P.S. the light switch only has 230v +/- 10% written on the specifications, so I dunno if it's 50hz or 50hz / 60hz, or that if frequency would even matter.
Thanks in Advance.
penti is offline   Reply With Quote
Old 08-28-2012, 10:52 AM   #2
Rewards Points: 160
It will work fine in either country. Where is the picture or link to the switch in question.
Old 08-28-2012, 11:02 AM   #3
So I'm assuming that like appliances, switches only need to cut the current on and off, so it won't matter as to its voltage / frequency? Any idea since this is an IR remote dimmer switch (won't that in itself need power)?
Here's the link of what I'm planning on getting:
https://www.1stopelectrics.com/produ...iridium_black/
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Mystery Light Switch smokey847 Electrical 3 02-04-2012 10:44 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
