230/208 Volt 20 Amp A/C Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-15-2012, 09:52 AM   #1
230/208 Volt 20 Amp A/C question
Hi all,
I live in Canada and have bought a 230/208 Volt 20 amp A/C, the electrician came over and says this won't work on the house electrical system. I'm no electrician, but from a little research on google it should work???
Any thoughts would be appreciated.
Denis
degagnon@yahoo. is offline   Reply With Quote
Old 10-15-2012, 10:22 AM   #2
Rewards Points: 150
Originally Posted by degagnon@yahoo. View Post
Hi all,
Denis
Did he say it simply wouldn't work, or wouldn't work without modification to your existing system?
  • You probably don't have a 230V circuit to where you want to put the A/C; that would have to be added.
  • There probably isn't a spare 2-pole 20A breaker in your panel.
  • There may not be space in your current panel to mount the 2-pole breaker you need.
  • Adding the A/C might exceed the total current capacity of your existing panel.
Dave632 is offline   Reply With Quote
Old 10-15-2012, 10:27 AM   #3
Electrician called back
Hi Dave,
Electrician just called me back, he says it will work.
Thanks for you help just the same.
Denis
The Following User Says Thank You to degagnon@yahoo. For This Useful Post:
Dave632 (10-15-2012)
30 amp 220 volt to 110 volt Gregad511 Electrical 5 08-18-2012 07:11 AM
24 volt AC wiring in same conduit as 220 volt single phase and in same outdoor enclosure as 220 v silgle phase and 3 phase arbailey Electrical 5 05-24-2012 09:43 PM
Volt Meter Testing Question jkpyke Electrical 10 02-20-2012 02:28 AM
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 09:21 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
