-   -   230/208 Volt 20 Amp A/C question (http://www.diychatroom.com/f18/230-208-volt-20-amp-c-question-160144/)
degagnon@yahoo. 10-15-2012 08:52 AM
Hi all,
I live in Canada and have bought a 230/208 Volt 20 amp A/C, the electrician came over and says this won't work on the house electrical system. I'm no electrician, but from a little research on google it should work???
Any thoughts would be appreciated.
Denis
Dave632 10-15-2012 09:22 AM
Originally Posted by degagnon@yahoo. (Post 1031111)
Hi all,
Denis
Did he say it simply wouldn't work, or wouldn't work without modification to your existing system?
  • You probably don't have a 230V circuit to where you want to put the A/C; that would have to be added.
  • There probably isn't a spare 2-pole 20A breaker in your panel.
  • There may not be space in your current panel to mount the 2-pole breaker you need.
  • Adding the A/C might exceed the total current capacity of your existing panel.
degagnon@yahoo. 10-15-2012 09:27 AM
Electrician called back
Hi Dave,
Electrician just called me back, he says it will work.
Thanks for you help just the same.
Denis
