220v Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 02-25-2008, 07:00 PM   #1
sbroco
Question
220v wiring
i have an existing 220v live running in my workshop, but i need to either add a line or splice the existing wiring to run a line to the other side of the shop. is this possible and how???? thank you.
bwill is offline   Reply With Quote
Old 02-25-2008, 07:20 PM   #2
Rewards Points: 6,652
If used for a specific piece of equipment, you will have to run another line for the other piece.
Old 02-25-2008, 07:22 PM   #3
What will the line be for. Do you need two of them based on the specs of any equipment you'll be using.
Need more info!
lg 38 is offline   Reply With Quote
Old 02-25-2008, 07:23 PM   #4
Mrs.
Need more info!
Old 02-25-2008, 07:24 PM   #5
From the OP, it appears that they want to use on the other side, not that the equipment needs two lines on the same side of the shop. Most likely more for ease of use, then necessity.
Old 02-25-2008, 07:43 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Bwill, don't PM people with information regarding questions. This does nothing to let others help. Also, it goes against what these forums are all about.
Please post more info regarding this.
Old 02-25-2008, 08:00 PM   #7
sbroco
its just for ease. my partner uses one 220v line for various equipment and i need to have the same usage about 20ft away. we are both pretty much rookies at electrical so any help is much appreciated.
Old 02-25-2008, 08:08 PM   #8
joed's Avatar
Rewards Points: 11,588
Depending on what the equipment is you are using, you may not be able to use them both at the same time. Give us some more info on the equipment and the amp of the current line.
Old 02-25-2008, 08:30 PM   #9
Is this a commercial shop?
What are these machines?
Old 02-26-2008, 05:49 PM   #10
Is it 220 or 221?
If you REALLY want advice, you need to realize that this is like someone asking you what kind of saw to use to cut wood.
Then you have to go back and ask them what kind/size of wood then you'd have to go back and ask what the application was (field or shop).
There's lots of differnt wood products and lots of different tools for cutting them.
220/221 is offline   Reply With Quote
Old 02-27-2008, 06:41 AM   #11
When is fishing season?
CowboyAndy's Avatar
221???
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 02-27-2008, 07:48 AM   #12
Why can't you install a disconnect/breaker the same amps as the wire/feed has, and run to the other side of the shop from there. with the same size wire. If the old work is installed correctly.
RobertS is offline   Reply With Quote
question about 220V cd player vs 120V sdipiet@msn.com Electrical 2 11-25-2007 04:23 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Wiring a 220v dryer receptacle pjpjpjpj Electrical 8 06-05-2007 05:08 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
