Old 04-25-2011, 08:29 PM   #1
220V Receptacle Near Gas Connection
I am planning on running a new 6/3 cable for a dual fuel range I am buying. I also need to run a gas line to the same general area for the gas cooktop part of the range. I have looked in the NEC, but I cannot find anything that mentions any separation requirements for the receptacle and gas connection. Is there anything I am missing, or can I just go ahead and run both of the gas and electrical to the same stud bay and have no code violations?
chronojosh is offline   Reply With Quote
Old 04-25-2011, 08:46 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Originally Posted by chronojosh View Post
........., or can I just go ahead and run both of the gas and electrical to the same stud bay and have no code violations?
Yup. Go ahead and do just that.
There is no restriction or problem with it.
Old 04-26-2011, 02:17 AM   #3
" Euro " electrician
frenchelectrican's Avatar
Go for it there is no restriction at all and it is pretty common pratice to see that being done in that way.
Merci,
Marc
Old 04-26-2011, 06:48 AM   #4
Lic Elect/Inspector/CPO
This isdone all the time.
NJMarine is offline   Reply With Quote
Replacing receptacle with GFCI wiring problem braden Electrical 8 04-06-2011 09:32 AM
low voltage reading at receptacle 2 ball cane Electrical 5 04-06-2011 01:07 AM
Receptacle type for 220v in workshop? Roy Rowlett Electrical 6 09-11-2009 04:49 PM
220v 16.8amp Receptacle Install mcbmoreno Electrical 5 09-13-2008 10:37 PM
Wiring a 220v dryer receptacle pjpjpjpj Electrical 8 06-05-2007 05:08 PM
