220v Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-06-2012, 11:03 PM   #16
MT Stringer's Avatar
Rewards Points: 198
I went to Lowes this evening and found all the parts to make the extension cord and change out the breaker and receptacle. So I have more latitude in my search for another saw. If it comes down to a 220v saw, I now know I can provide power to it.
Also, if I buy a 110v model, I could also upgrade my shop vac buy buying a dust collector that runs on 220v and take advantage of the available 220v. :-)
Thanks for all the helpful advice.
Mike
MT Stringer is offline   Reply With Quote
Old 10-07-2012, 11:53 AM   #17
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Mike
You are welcome!!
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 10-07-2012, 12:18 PM   #18
JOATMON
ddawg16's Avatar
Rewards Points: 798
Mike
Just an FYI.....it's actually 120/240
It's common for people to use 110/220 when talking about AC....but if your voltage is actually that low....you have issues.
ddawg16 is online now   Reply With Quote
Old 10-08-2012, 06:04 PM   #19
Rewards Points: 266
Originally Posted by Speedy Petey View Post
Because a 240V motor will not work as hard and will start MUCH easier as compared to the the equivalent 120V motor.
Are you sure?
ionized is offline   Reply With Quote
Old 10-08-2012, 06:08 PM   #20
Rewards Points: 266
If this is an old installation, there may not be a separate ground in the outlet. Strictly speaking, won't new cable with separate ground and neutral be needed for any major changes? If that is the case, an extension cord may be the only option.
Why not add a sub panel in place of the outlet if the cable is correct for that?
Old 10-08-2012, 06:22 PM   #21
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Originally Posted by ionized View Post
Are you sure?
He is correct.
Old 10-08-2012, 06:38 PM   #22
Rewards Points: 266
My understanding is that there is no significant difference if the cabling is adequate in both situations:
120V lower voltage, higher current, power =
240V higher voltage, lower current, power =, less expensive cable is an advantage in new installation.
Three phase is, of course, another story entirely.
Old 01-05-2013, 11:31 PM   #23
Rewards Points: 198
And now for an update.
I bought a Grizzly 1023RLW table saw -3hp, prewired for 240.
Making the extension cord was easy.
Thanks for all the tips and advice.
Note: It will always be 110/220 for me. :-) Y'all can call it what you want. Hard to change the nomenclature after 50 years.
Old 01-06-2013, 12:54 AM   #24
JOATMON
ddawg16's Avatar
Rewards Points: 798
220, 221. What ever it takes.
Old 01-06-2013, 10:58 AM   #25
Rewards Points: 776
... Making the extension cord was easy.
Make sure you use NEMA 6-20 style plugs for the cord and 12AWG wire.
Also be sure there isn't anything else on this circuit. Once you liven it to 240VAC it won't be friendly if a rogue receptacle you missed gets up in voltage.
Surface mount conduit for a garage is pretty straight forward. Run it up in top corner or along the floor against the sill plate. The conduit provides the necessary mechanical protection. Avoids hacking up the drywall.
curiousB is offline   Reply With Quote
Old 01-06-2013, 01:18 PM   #26
Master Electrician
Rewards Points: 3,678
Power used is the same. Voltage drop is the difference.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
frenchelectrican (01-06-2013)
Old 01-06-2013, 02:43 PM   #27
" Euro " electrician
frenchelectrican's Avatar
I know this is semi old thread but as long the OP did bring it up to the date that is fine but I will addressed to the quouter ( Ionized ).,
The wattage will be always be the same no matter the voltage you using.
Well techally wise the higher voltage will aid the motour starting much better due it will withstand much better voltage dip during motour starting and it will run little better.
I have alot of hevey power tools and equiment useally set up for 240 volt or higher ( Mine shop in Wisconsin is classeifed as commercal so I can get 480 volts without issue )
The other big advange with 240 volt equiment is useally the lights are not really affected during the start up they may flicker a second but not much as if that was on 120 volt conferation then it will show up depending on the circuit is lay out ( connected )
Merci,
Marc
220v question dcw Electrical 11 04-06-2012 11:05 AM
Generator connection Question - Final Plan Apollo67 Electrical 24 01-30-2012 08:44 PM
Powering a 50A 220V outdoor swimspa firisland1 Electrical 9 11-25-2008 07:51 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
