Old 04-05-2012, 11:23 PM   #1
dcw
220v question
I have 110v in my detached garage. I need a new air compressor so I was going to get an electrician to wire it up for me. I was quoted $600 for the work. He told me to get enough 6/3 wire to run from my breaker box to the bottom corner of my house. He said from there he would hook that into a junction block and hook it to #6 to run in conduit out to the garage. I was wondering how he could do that with just the 1 wire #6? I have asked a second electrician and he said the same thing.
dcw is offline   Reply With Quote
Old 04-05-2012, 11:31 PM   #2
Electrical Contractor
220v question
6/3 is a cable with 3 insulated and one bare wire.
He connects these wire inside a junction box, and used induvidual wires inside the conduit to the garage.
Is the price just for labor, or is he suppling everything?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 04-05-2012, 11:32 PM   #3
Licensed Electrician
k_buz's Avatar
220v question
He is going to splice a #6 THHN/THWN to each conductor contained in the 6-3.
Old 04-05-2012, 11:44 PM   #4
dcw
220v question
he said just the one #6 in the conduit....
So you can splice the 1 wire to the 2 wires on the 6/3 then use the ground off the 110v?
I know how to hook it up if it was 6/3 all the way out. I'm just trying to figure out how this would work
Old 04-05-2012, 11:46 PM   #5
k_buz's Avatar
220v question
It wouldn't, you must be misinterpreting something.
To elaborate, if you spliced the black and red to a single wire, and the 6-3 was wired for 240V you would have an impressive boom.
Old 04-05-2012, 11:48 PM   #6
joed's Avatar
220v question
He is going to have to disconnect the current wires to the garage and replace them. You are only allowed one feed to your detached building. If the current feed is already #6 wires in conduit then he only needs to add one more wire to give you the 240 volts.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 04-05-2012, 11:53 PM   #7
k_buz's Avatar
220v question
is he trying to reuse the existing conduit?
Old 04-05-2012, 11:53 PM   #8
dcw
220v question
yeah I must have. I will check tomorrow. He never checked my wires or anything though.
Old 04-05-2012, 11:56 PM   #9
dcw
220v question
this guy is good. I probably misunderstood his whole plan.
Old 04-06-2012, 12:02 AM   #10
k_buz's Avatar
220v question
I'll attempt to explain it.
After you run the 6-3 you will have 2 hots, a neutral, and a ground to where the existing feed to the garage exits the house. The existing underground pipe has 2 conductors...a hot and a neutral. He will either pull out the existing wires and pull in larger conductors for the increased load or add one conductor to the existing feed to create a 120/240V multi wire branch circuit.
What I am curious about is why you would need 6-3. Is he installing a sub panel in the garage? What does the compressor draw?
Old 04-06-2012, 09:34 AM   #11
dcw
220v question
he is putting 6/3 so if I ever get anything that draws more like a welder
Old 04-06-2012, 11:05 AM   #12
joed's Avatar
220v question
If you want lights to go along with the compressor you need a sub panel to create the different circuits.
Generator connection – Question - Final Plan Apollo67 Electrical 24 01-30-2012 08:44 PM
Powering a 50A 220V outdoor swimspa firisland1 Electrical 9 11-25-2008 07:51 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 11:40 PM
