220V Quandry... - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2010, 04:52 PM   #1
220V quandry...
I'm converting a room from a kitchenette to a bathroom, and am installing a big fancy shower with a steam generator. It requires a 15a/220V outlet. The room, which is located as far away from the breaker as physically possible and still be in the same house, has three normal 3 wire/15a/110 outlets (same breaker, shared with adjacent room), and an outlet for a stove, which seems to be on a 40a/220/4 wire.
The 220 outlet seems to be on the same breaker as the stove located a floor beneath it...I don't know this for sure, but there are no other 220 breakers in the panel, so it seems a fair wager. Naturally I'll be testing it to make sure before making any upgrades.
Given the scenario, I figure I have two options: run a new 220 on its own breaker (bleh), or make that existing 220 work. To do the latter, I believe I'll need to put a 15a breaker in somewhere before the shower plug.
How would you do this job? Are there options I'm not realizing? Am I stuck with new wiring or can I make the existing 220 work? How?
WoodyNaDobhar is offline   Reply With Quote
Old 10-19-2010, 05:01 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
You are stuck with running new wire, or forget the shower!
Do you have model # for the generator?
We have had some unsafe intrsuctions on other generators from across the sea before.
Main box feeding 220v and 110v brearker box off a 50am breaker? uvamosk Electrical 30 10-14-2009 11:46 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
220V Wiring Mdbuilder Electrical 18 07-11-2008 12:14 AM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 11:40 PM
question about 220V cd player vs 120V sdipiet@msn.com Electrical 2 11-25-2007 04:23 AM
