220v Plug End Differences - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-03-2011, 06:59 PM   #16
Rewards Points: 105
Originally Posted by nap View Post
no. on the heater there will be only 3 wires: they could be just about any color but one should be green. That will go to the ground terminal in the plug usually a green screw). The other 2 wires will go to the hot wire terminals (usually brass colored screws) There will be nothing on the neutral connection (usually a silver colored screw)
what mpoulton was meaning to say is you will not connect anything to the neutral connection of the plug. The neutral wire would be a white wire. In your situation, you aren't going to actually have any white wires to use as a neutral although one of the wires in your cord on the heater might be white, it still isn't a neutral wire if your heater is a straight 240 volt appliance.
Ok..........thanks for explaining that a little clearer, thanks!
gmbwrenchn is offline   Reply With Quote
Old 05-03-2011, 08:26 PM   #17
Missouri Bound's Avatar
I'm curious...are you indending to have this heater permanently installed? I would think it would be cheaper to wire it in directly than pay for the gas to keep the generator running.
Old 05-03-2011, 08:56 PM   #18
Rewards Points: 105
No.......just want to use it during the winter months in the garage. Need the generator as well for when are electricity goes out during a storm, which is quite frequent around here. So are basement doesn't get flooded. Need it for the sump pump. Plan on moving in the near future that's why I don't want to run 220 out to the garage. Thanks for the help.
Old 05-03-2011, 09:11 PM   #19
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Are you using a gas generator to power a heater? It would be more efficient to use propane and just use a propane heater. That way your not converting heat to movement, then to electricity, and then back to heat again. Just a thought...
As far as the wiring, you could probably change the plug provided that the wattage/voltage matches.
The Following User Says Thank You to Red Squirrel For This Useful Post:
mpoulton (05-03-2011)
Wiring a 220V dryer plug on a 110 power panel , in Mexico dtedham Electrical 1 04-14-2011 06:15 PM
Replacement plug for an old box freezer brich Electrical 1 05-11-2010 07:44 AM
Can you change a 220v plug on a dryer clueless_03 Electrical 6 08-30-2009 02:39 AM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 10:49 AM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 11:40 PM
