220v Plug Differences - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-17-2012, 06:23 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Thank you a7ecorsair. That makes it clearer.
It IS a 120/240v. I absolutely HATE instructions from idiots like this. EVERYWHERE it says 240v, then in one little spot, on one page, it says 120/240v.
So where in the specs do they mention the 6.5kW draw (other than that little box)???
Old 04-17-2012, 06:28 PM   #17
Master Electrician
Rewards Points: 3,680
I feel your pain.
brric is online now   Reply With Quote
Old 04-17-2012, 06:29 PM   #18
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
If you can not install a new circuit for the MW, you had best return it and get a 120 volt model. Even then it will require a dedicated 120 volt circuit in the cabinet above the MW.
Coastal South Carolina
Old 04-17-2012, 06:31 PM   #19
I=E/R
a7ecorsair's Avatar
The first link provided was to some sales site. I downloaded the installation PDF from GE.
a7ecorsair is offline   Reply With Quote
Old 04-17-2012, 07:10 PM   #20
ktkelly, any further input?
If there is not a 30A-120/240V line for it, and as you say "there is absolutely no way to run new wiring" then your ONLY recourse is to return the micro and get the 120v model.
The dryer can use an older non-grounding circuit as described in a an earlier post.
Old 04-17-2012, 07:45 PM   #21
Rewards Points: 1,450
There is currently a three prong 240v outlet in the location, as there was previously an earlier model of this same microwave in the same location.
I gather that it was a DIY install, and had the standard "dryer" cord in place of the newer four prong cord.
Don't know that for sure, but I do know that it was working before...
Since I do want this to be to code (so much in this pace was not), if I were able to pull an additional wire, would pulling a single 10ga for use as the neutral work?
The old unit (from 1999) went bad, shortly after I bought the place this past July, and I figured I'd rather have a new unit that has a warranty rather than have the old one repaired.
Repair comes with 90 day parts warranty. New comes with 10 year parts warranty (from supplier).
By the way. I am not a part of the 1%. Wish it were so. If it were, I'd have "my guy" do the work....
ktkelly is online now   Reply With Quote
Old 04-17-2012, 08:56 PM   #22
Master Electrician
Just a lame attempt at humor, no offense meant.
Old 04-17-2012, 09:14 PM   #23
Wasn't offended. Just hopeful...
Can't seem to win the stinkin' lottery, so I'll remain a part of the 99% (or less)....
As to the neutral and ground wire on these things, I think it's sort of funny, since both the neutral and the ground wire connect to the same buss bar in the panel.
One more of those deals where th code is ever changing....
Old 04-17-2012, 09:37 PM   #24
This is a very common misconception. The fact that they are connected to the same place in a main panel has nothing to do with that their purpose is outside the panel.
Old 04-17-2012, 10:04 PM   #25
I=E/R
a7ecorsair's Avatar
I think you should turn off the breaker for this receptacle and then open up the box and see what is inside for wiring. You will need three insulated #10 conductors and one ground. There is a slim chance that there may be an unused conductor hiding in the box.
The old unit may have been straight 240 v but according to what we see in the installation guide, this unit requires a neutral for some 120 volt parts. Things like the blower, light, and touch panel power may use 120 volts and most likely the magnetron too. The only 240 could be the convection element.
What size breaker currently protects this circuit? It should be a two pole breaker.
Old 04-18-2012, 12:04 AM   #26
Currently on a 30amp double pole breaker.
I'll be back there next week, and will check pull the outlet just to be sure there's no other wire hiding out in the box unused....
Ya never know....
Old 04-18-2012, 03:20 AM   #27
" Euro " electrician
frenchelectrican's Avatar
Ya know the funny thing when I was reading the 240 volt mircowave oven and I say Quoi ?? 30 amp circuit IMO that really don't make 100% sense due the wattage rating is simair over our European side and we only used legit 240 volt 16 amp circuit but our French code will say need 20 amp circuit anyway.
Now for that Mircowave useage that is something I don't see very often in state side espcally if wired up for 240 volts IIRC it was just standard 20 amp circuit sans netural in there. that was many years ago I think it was JennAir if I did remember the manufacter correct.
Merci,
Marc
220V & 110V outlets rickinnocal Electrical 21 05-13-2011 02:16 PM
220v Plug end differences gmbwrenchn Electrical 18 05-03-2011 09:11 PM
Wiring a 220V dryer plug on a 110 power panel , in Mexico dtedham Electrical 1 04-14-2011 06:15 PM
Can you change a 220v plug on a dryer clueless_03 Electrical 6 08-30-2009 02:39 AM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 10:49 AM
