220v Plug Differences - Electrical - DIY Chatroom Home Improvement Forum
Old 04-17-2012, 12:53 PM   #1
Rewards Points: 1,470
220v plug differences
I have a 220v Microwave, and a 220v dryer, that came with a four prong plug cords attached (they were used in newer homes).
The current outlets are three prong outlets and there is absolutely no way to run new wiring.
Just need to change the cords on the microwave and dryer to the old style three prong ones?
Opinions?
ktkelly is offline   Reply With Quote
Old 04-17-2012, 01:58 PM   #2
Rewards Points: 1,536
Can you find a 4 prong to 3 prong adapter that fits in the wall receptacle and you plug the appliance into that?
Note that for the dryer, depending on how many amperes it needs, its plug may or may not be the same as that for the microwave oven. But it's still a 240 volt plug.
Old 04-17-2012, 02:36 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
It is compliant to install a 3 wire cord on a dryer to use with an existing properly wired 3 wire dryer receptacle.
Need more info on the MW. What is the NEMA configuration of the cord and receptacle
http://www.stayonline.com/reference-...ght-blade.aspx
Or post a picture of each.
Coastal South Carolina
Old 04-17-2012, 02:39 PM   #4
Master Electrician
Rewards Points: 3,918
Say what!!!!!!!!!!!!!
brric is online now   Reply With Quote
Old 04-17-2012, 02:49 PM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
To change the plug from a 4 prong to a 3 you need to install a bonding jumper from the neutral terminal to the dryer’s frame. The bonding jumper is either a metallic strap (typically copper or copperclad) or a green wire that is connected between your dryer’s neutral (white wire) terminal and the green ground screw connected to your dryer’s frame.
Installing this bonding jumper is an extremely important step when changing from a 4-wire to a 3-wire power cord to prevent electrical shocks when touching anything metallic on your dryer.
sublime2 is offline   Reply With Quote
Old 04-17-2012, 04:24 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
What kind of micro was 240v? I have never seen a household micro that was 240v.
Also, a 240v micro would NOT have needed a 4-prong plug and cord.
Can you give us the specs on the micro?
Speedy Petey is online now   Reply With Quote
Old 04-17-2012, 04:37 PM   #7
I=E/R
a7ecorsair's Avatar
Maybe it makes popcorn in 15 seconds
a7ecorsair is offline   Reply With Quote
Old 04-17-2012, 04:49 PM   #8
GE Advanitum PSA2201RSS
http://www.number1direct.com/product...FeJe7Aod_wxHyQ
You guys don't get around much do you?.....
If you ever use one of these you would never go back to a conventional microwave.
Not just very fast, but you can cooks things like steaks, and they'll come out as if they were done on the grill.
Old 04-17-2012, 04:57 PM   #9
I=E/R
a7ecorsair's Avatar
Can we assume when you say the current outlets are three prong that you are referring to a standard US 120 volt receptacle that is normally found in a kitchen?
Your microwave requires a 30 amp circuit which means #10 wire.
Old 04-17-2012, 05:10 PM   #10
I get around plenty, and I have seen 100's of OTR micros. It's just something doesn't add up.
It says 975 micro watts. Yet it requires a 240v 30A circuit?
Next, this is NOT just an OTR micro. It is also a convection oven, so it is a tad bit more than a "microwave". Something you neglected to mention originally.
Then it says something about a 1500 watt element.
The specifications seem more like an advertisement than technical specs.
Under power it simply says 30A, 240v, and 975 "Microwave Watts (IEC-705)", whatever that means.
975 divided by 240v = 4 amps. Where are the other 20 amps coming from???
Again, the specs say 240v, NOT 120/240v. So this unit requires two hots and a ground. A neutral is not required or needed.
Old 04-17-2012, 05:12 PM   #11
Master Electrician
Speedy, I have installed several 120/240 volt 30 amp micros. They do exist. Page 3 of the installation instructions. Nema 14-30 cord cap.
Old 04-17-2012, 05:13 PM   #12
Straight micros? In a residence?
I have NEVER seen a 4000+ watt micro.
Old 04-17-2012, 05:16 PM   #13
Master Electrician
See my edit to post #11. They're for the 1%. Not the 99% of us.
Old 04-17-2012, 05:19 PM   #14
I=E/R
a7ecorsair's Avatar
If you install this you will need a new circuit. Here is some clips from the manual.
The Following 3 Users Say Thank You to a7ecorsair For This Useful Post:
brric (04-17-2012), frenchelectrican (04-18-2012), Speedy Petey (04-17-2012)
Old 04-17-2012, 05:20 PM   #15
OK, this unit is still a convection oven and not just a micro.
And if the voltage is 208/240v WHY are the "recommending" a 14-30???
220V & 110V outlets rickinnocal Electrical 21 05-13-2011 01:16 PM
220v Plug end differences gmbwrenchn Electrical 18 05-03-2011 08:11 PM
Wiring a 220V dryer plug on a 110 power panel , in Mexico dtedham Electrical 1 04-14-2011 05:15 PM
Can you change a 220v plug on a dryer clueless_03 Electrical 6 08-30-2009 01:39 AM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 09:49 AM
