Old 08-06-2012, 06:31 AM   #1
Unhappy
220v to garage
I would like to add a 220v socket, or convert one of the current 110v sockets in my garage for welder use. The problem is, my circuit panel is not in the garage. It's in the laundry room directly across from the garage with a hallway in between.
Would it be better to convert A 110 socket or run a dedicated 220 socket? And how would I go about doing this?
sen2two is offline   Reply With Quote
Old 08-06-2012, 06:37 AM   #2
220v to garage
If you want to do it to code,
you will have to run another line !
Can you not follow the route of the original line ?
Do you want an earth and a neutral ?
dmxtothemax is offline   Reply With Quote
Old 08-06-2012, 08:04 AM   #3
Licensed Electrician
k_buz's Avatar
220v to garage
Run a new circuit. Do you have the welder? What are its specs?
Not a fan of the new layout.
k_buz is online now   Reply With Quote
Old 08-06-2012, 12:16 PM   #4
220v to garage
The welder is an ac/dc 175amp tig welder.
How would I go about running a new line/circuit? I never ran any electrical in a house before...
Old 08-06-2012, 01:36 PM   #5
" Euro " electrician
frenchelectrican's Avatar
220v to garage
If you never ran it before I think it will be the best move have the electrician come in and assit you on that one this will be the safest move on that instead of someone whom not really confortable with the electrique system.
Merci,
Marc
Old 08-06-2012, 02:13 PM   #6
220v to garage
While that would be a good choice. I am a DIY person and always have been. That is why i am asking this here.
If I do my research and get questions answered here, I should be able to do it safely and correctly.
Old 08-06-2012, 03:20 PM   #7
220v to garage
I found the book Wiring Simplified to be both affordable and helpful. It makes a good read. Home Depot has it, but their copy was out of date when I purchased mine, so I bought it from a bookstore. You want the 43rd edition, based on the 2011 National Electrical code. (You are in the U.S., right?)
What is the rating on the input of the welder? Not only would it probably be breaking electrical code (I am in Slovakia right now, so I don't remember for sure how it would be for the US), but also it is unlikely that the existing wires are large enough to handle the current needed.
You may want to go ahead and install a larger cable and circuit breaker however, if you anticipate ever getting a bigger welder out there. The cost will not be too much more and will save you the frustration of having to run another line out there.
How many prongs does your welder's plug have?
Generally, it is pretty straightforward-- you just need to add the appropriately sized breaker into the panel, pull the cable to the garage, and install the outlet.
Of course there are all sorts of details:
  • You must buy a breaker compatible with your panel (which usually means the same brand).
  • If your garage is not dry-walled, then (if I remember correctly, but check) you may need to run the cable through conduit where it is exposed.
  • You'll get to practice dry-wall patching as well, since it will be certainly necessary to cut some holes in the wall to get to the breaker panel and pull the cable.
freedomlives is offline   Reply With Quote
MWBC to Garage Questions benleef Electrical 3 02-22-2012 12:02 PM
220V 15A outlet in Garage curiousB Electrical 97 01-27-2012 10:53 PM
220v service for garage chevelle Electrical 2 11-11-2011 06:23 AM
How to wire a detached Garage? (w/ Conduit?) FLintonRice Electrical 7 06-27-2011 02:08 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 04:56 PM
